Hondata + what else?
Old Aug 22, 2003 | 11:34 PM
Hoodwinked's Avatar
Default Hondata + what else?
Hi,
I am looking into the Hondata s100 for my 99-00 Civic Si boosted at 7 psi. My goal is reliability, being a daily driver. What else do I need to get along with the Hondata? What size injectors? I am not looking to go past 10psi of boost. Do I need some sort of resistor box? Thanks
Old Aug 22, 2003 | 11:38 PM
LiLOtaku's Avatar
Default Re: Hondata + what else? (Hoodwinked)
If you plan on getting injectors, RC actually makes 550cc injectors that are saturated, so you won't need the resistor box.
You can also buy Nippon Denso injctors that are 550cc that are saturated as well.
Both injectors are great, I personally have Denso's on my 99 Si.
If you have anymore questions, feel free to IM me.
Old Aug 22, 2003 | 11:47 PM
Boost2NA's Avatar
Default Re: Hondata + what else? (LiLOtaku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLOtaku &raquo;</TD></TR><TR><TD CLASS="quote">If you plan on getting injectors, RC actually makes 550cc injectors that are saturated, so you won't need the resistor box.
Also you are gonna need to convert to OBD-1. Most common ECU to run is a P-28 found in the older Ex civics (92-95). You will also need a OBD-2 to OBD-1 wiring harness as well. Hope that helps
If you have anymore questions, feel free to IM me.</TD></TR></TABLE>
Old Aug 22, 2003 | 11:50 PM
LiLOtaku's Avatar
Default Re: Hondata + what else? (Boosted99Si)
doh!,
forgot about the harness and ECU part, my bad .
Thanks Boosted99Si
Hey HoodWinked, if you can't find someone to do an ECU for you(chip it for hondata). A friend of mine does them for a really good price.
Old Aug 23, 2003 | 12:32 AM
Chris1091's Avatar
Reliability is in the tuning and maintenance.
b18psi
Jul 2, 2004 02:24 PM
integracivic94
Dec 30, 2003 06:49 AM
GOLDBERG
May 6, 2003 05:00 PM
civcexcoupeblack
Dec 16, 2002 01:16 PM
PM-Performance
Nov 4, 2002 08:40 AM
