final part of turbo install, need help asap
Old Aug 21, 2003 | 08:36 PM
Mr. Softee's Avatar
Default final part of turbo install, need help asap
I chipped my ecu myself with tegasaurus. I thought we did a good job. We tried it on his car, i thought, and it worked fine. Im pretty sure he revved it up to like 4000 and it worked fine on his car. I put it into my car with a new chip i made and it goes into limp mode. Right now i have no idea why. I tried another ecu in my car and i got it to go above 4000 rpm so i know its JUST my ecu that is the problem.
anyway, does anyone know why an ECU would go into limp mode? it worked fine before chipping.
this is the last thing i need to fix before my car runs fine
sam
Old Aug 21, 2003 | 09:09 PM
civicmark's Avatar
Default Re: final part of turbo install, need help asap (94goldjungsr)
check the connections of your socket to the board, when we chipped my friends(mazda) there was a bad connection at first and it ran like ****.
edit: put in the origional chip and see if it still runs limpo
Modified by civicmark at 6:30 AM 8/22/2003
Old Aug 21, 2003 | 09:12 PM
Mr. Softee's Avatar
Default Re: final part of turbo install, need help asap (civicmark)
i resoldered some of those connections. im going to try again.
thanks for the tip
sam
Old Aug 21, 2003 | 09:23 PM
Blown90hatcH's Avatar
Did you try another chip?
Old Aug 21, 2003 | 09:25 PM
TeStUdO's Avatar
try cutting the j1 to put it back to stcok just to see if it goes out of limp mode. if so then you messed up the soldering somewhere
Old Aug 21, 2003 | 09:29 PM
Mr. Softee's Avatar
Default Re: (TeStUdO)
i cut the j1 on an ecu i did in the past and it didnt take it out of limp mode.
Old Aug 22, 2003 | 02:37 AM
Mr. Softee's Avatar
Default Re: (94goldjungsr)
i fixed it. just resoldered everything.
Old Aug 22, 2003 | 07:39 AM
civicmark's Avatar
good to hear
dlx111
Jan 1, 2019 04:41 PM
aznboi_2
Mar 25, 2009 01:35 PM
quicksilvia
Jun 21, 2006 04:30 PM
5STAR3
Mar 20, 2004 04:40 PM
100whplusperliter
Aug 9, 2003 11:35 PM
