how to release fuel pressure when install injectors
How do i release fuel pressure when install injectors?
also do you guys run lean or rich with 450cc and vafc hack during IDLE and rpm before boost?
say your turbo boost kicks in at around 3000rpm.. so basically 0-3000 is in normal vacuum, do you run from 0 to 3000rpm same as idle settings or what?
Re: (2000vsm)
the helms just says to open the fuel cap and loosen the banjo nut on the return line. Thats what i did...the fuel that was in the rail obviously came out but no problems.
midwesta
10
08-03-2005 03:06 AM
