HELP! I think my deltagate leaks vacuum?
hey guys. i don't think my deltagate is good. i have a vaccuum leak and when i pinch the vacuum line from the deltagate, my leak goes away.
have you guys ever heard of this, could my deltagate be missing some pieces inside it?
Re: HELP! I think my deltagate leaks vacuum? (shivic)
Maybe your deltagate has a tear in the diaphram. Maybe the line going to the deltagate is no good. Also, you don't need to hook up your deltagate to a vacuum line. It only needs boost. I always weld a little nipple onto my intercooler piping between the IC and the TB and run it from there. But you need to check your wastegate to make sure the diaphram isnt torn.
