Here are the pics of my problems with the manifold....
Old Aug 21, 2003 | 11:58 AM
racinskittle's Avatar
Default Here are the pics of my problems with the manifold....
As you can see, the compressor housing is hitting the damn block.
That's how much more i need. Im gonna see if i can pick up a manifold quickly
Other than that, everything is going very well.
Just need to get this **** done b4 college
Old Aug 21, 2003 | 12:00 PM
needboost's Avatar
Honda-Tech Sponsor
That sucks.
Take it to a machine shop, and have them angle the flange out a bit,
Old Aug 21, 2003 | 12:07 PM
BRYAN1's Avatar
Default Re: (needboost)
or have someone fix it that can weld.
Old Aug 21, 2003 | 12:14 PM
minivan81's Avatar
Default Re: (BRYAN1)
If the webbing part is in the way, try and notch the block and see if you can get some clearance. Just don't grind too much
Old Aug 21, 2003 | 12:32 PM
project dc2's Avatar
Default Re: (minivan81)
who built it ? it possibly might work with compressor on drivers side.
Old Aug 21, 2003 | 12:35 PM
RenoRacing's Avatar
Default Re: (project dc2)
we can fix you up and have you going strong skittle, no worries!
Old Aug 21, 2003 | 01:33 PM
Turbocivic94's Avatar
Default Re: Here are the pics of my problems with the manifold.... (racinskittle)
Did u notch the block, try doing that before buying another one.
Old Aug 21, 2003 | 02:05 PM
shortyz's Avatar
Default Re: Here are the pics of my problems with the manifold.... (25 PSI CRX)
uhm, where the hell is your downpipe going?
dont u wanna turn that turbo around so your downpiipe just takes a 90degree bend straight down to the pan?
Old Aug 21, 2003 | 02:13 PM
Default Re: (HavokRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HavokRacing &raquo;</TD></TR><TR><TD CLASS="quote">we can fix you up and have you going strong skittle, no worries! </TD></TR></TABLE>
Thanks a bunch!! I can't wait lol.
ON a side not, i will be clocking the housings so the DP will work.
This manifold DOES work when the compressor is on the drivers side! Works damn good. The only problem is that I dont have a flange that will fit my exhaust side that will make a down pipe so i can still keep my internal wastegate.
Anyone know where i can buy a flange where I can use an internal wastegate??? RIght now i am using the O2 housing. THIS IS WHERE THE PROBLEM COMES IN! when the compressor side is on the drivers side, the outlet of the O2 housing faces the damn block lol I cant clock the exhaust housing cuz then the return will be upside down.
THanks for the input! it's appreciated.
THanks again HAVOK!
Old Aug 21, 2003 | 02:56 PM
trbob16a's Avatar
Default Re: (racinskittle)
Just make a plate adapter to move it out an inch. Bolt the adapter to the manifold, the bolt the turbo to the adapter on a second set of screw holes about a half inch out. Easy, cheap, effective.
Old Aug 24, 2003 | 06:29 PM
RenoRacing's Avatar
Default Re: (trbob16a)
Here ya go! i just finished her up, not bad for the price huh? The porting work came out pretty smooth, i was rather impressed with my self. you got lucky that i couldn't get any tee's. lol I'll ship it out tomorrow. thanks again. Let me know how you like it.
Old Aug 24, 2003 | 07:23 PM
Holy crap! That's bad ***! HUGE FOR havokracing!!!! Great seller
Trojan Man
Nov 14, 2008 11:33 PM
twisted civic
Aug 13, 2005 08:46 PM
SPOOLINmatt
Jan 20, 2005 08:39 AM
Greyout
Jun 28, 2003 10:30 AM
