External WasteGate with Blitz Boost Controller
Old Aug 23, 2003 | 12:49 AM
TurboTeG4's Avatar
Default External WasteGate with Blitz Boost Controller
Ok im goin to put my boost controller on my new car, so bottom hose on wastegate goes to turbo compressor , The top side goes to my valve unit outlet, but the inlet to the valve unit comes from between the turbo and throttle body. Im using a drag 3 kit on my teg, do I have to drill a fitting into my turbo pipe to run to my boost controller valve unit????
Old Aug 23, 2003 | 01:58 PM
TurboTeG4's Avatar
Default Re: External WasteGate with Blitz Boost Controller (turbocivic4)
Old Aug 23, 2003 | 10:28 PM
RH+G's Avatar
Yeah. DOnt forget to run that skinny black line also
Old Aug 24, 2003 | 06:28 PM
TurboTeG4's Avatar
Default Re: External WasteGate with Blitz Boost Controller (RH+G)
Answer me , do i have to tap a vacuum into my turbo pipe???
Old Aug 24, 2003 | 06:59 PM
TurboDANDEE's Avatar
"IN" comes from the turbo port/or vacuum source
"OUT" needs to go to the top port of the wastegate
side port of the wastegaete goes to the turbo/or vacuum source
so u can splice the "IN" port of the box and side port of the wastegate cause it needs to get the same reading. am i making sense?
Old Aug 24, 2003 | 10:58 PM
RH+G's Avatar
Default Re: External WasteGate with Blitz Boost Controller (TurboDANDEE)
Yes you have to tap into your pipes
Old Aug 26, 2003 | 05:59 PM
TurboTeG4's Avatar
So the vacuum on the bottom side of the tial wastegate connects to the turbo(drag 3 kit) I see no vacuums connections on my turbo?? From that hose i can tap it for my inlet on my boost controller since that supposedly comes from the intake side of the turbo.
Old Aug 27, 2003 | 07:46 PM
RH+G's Avatar
You might not have any. When I hooked mine up i used seperate taps cause when we had it tee off the same tap it spiked. Try it we probaly had to play withe the gains but didnt bother too. The hose coming from the turbo went into the bottom of the wastegate and we drilled a tap into the the pipe connecting to the tb and put that to the inlet.
98integralsB18
Jul 25, 2009 07:29 AM
DIRep972
Sep 11, 2004 01:26 PM
VanHonda
Jun 8, 2003 04:01 AM
rbf351
Dec 17, 2002 06:10 AM
KLN
Jul 1, 2002 01:58 AM
