i dont know what to do next!
Old Aug 20, 2003 | 10:55 PM
civic.com.hk's Avatar
Default i dont know what to do next!
this is what i have now:
greddy turbo kit, bbk fuel pump, aem fuel rail, hks BOV, spearco intercooler, greddy boost controller, blitz turbo timer, random cat.
stock internal.
what's the next thing i should get now? should i get some DSM injectors or any other fuel system upgrades? or should i get some ignition upgrade first? i m on a tight budget. please tell me what to do. thanks~!!
Old Aug 20, 2003 | 10:56 PM
Default Re: i dont know what to do next! (civic.com.hk)
if i m getting ignition upgrade, which system and what brand should i go for?
Old Aug 20, 2003 | 11:00 PM
avex's Avatar
i'd skip the ignition and save up some cash and get bigger injectors and a standalone.
Old Aug 20, 2003 | 11:31 PM
Default Re: i dont know what to do next! (avex)
why though? so i dont have to work on the ignition at all?
Old Aug 20, 2003 | 11:35 PM
liam821's Avatar
25 Year Member
The stock honda ignition is pretty awesome. It will work fine for your application. Personally id save up for injectors and a standalone (hondata or aem ems). Id recommend the hondata for ease of use and cost.
liam
Old Aug 20, 2003 | 11:40 PM
NyQuiL's Avatar
sorry to go a little bit o/t
but im shooting for 450+whp how much can the stock honda ignition handle and there are no really ignition upgrades you guys would recomend?
does it matter on setups cause im gona be runnin
8.5:1 comp, built head and block, 99 ls.
Old Aug 20, 2003 | 11:58 PM
avex's Avatar
Default Re: (NyQuiL)
this is from motormatrix.com's post in a diff thread.
"after 15psi and 450whp youll need an ignition system. i like the msd digital 6 or 7 myself."
Old Aug 21, 2003 | 12:02 AM
liam821's Avatar
25 Year Member
Default Re: (avex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avex &raquo;</TD></TR><TR><TD CLASS="quote">this is from motormatrix.com's post in a diff thread.
"after 15psi and 450whp youll need an ignition system. i like the msd digital 6 or 7 myself."</TD></TR></TABLE>
Id agree
liam
Old Aug 21, 2003 | 05:38 PM
Default Re: (liam821)
forgot to tell u guys:
i m running 5psi low boost and 8psi high boost(engine has 73xxx miles on it). i will be installing the 8 ga wire from home depot asap(ground wires, less then $2.00), i hope they can help a little. but seriouly, what else do i have to upgrade? what about things such as changing gaskets, timing belts, or some other stuff that might be wored out from the boost?
Old Aug 21, 2003 | 05:41 PM
Default Re: (civic.com.hk)
or is it time for me to flush my radiator and the transmition oil? what kind of maintainance should be done? i had this turbo kit on for a little over a year now, and i change oil every 3000 miles(i also add stuff like fuel injector cleaner, oil cleaner, gas cleaner, etc). what else can be done?
Old Aug 21, 2003 | 05:42 PM
any opinions and tips are welcomed. thanks!
90teg
Oct 19, 2004 06:48 AM
epmugenlude
Mar 27, 2004 05:56 PM
jamal-188
May 7, 2002 08:16 AM
2000Si-at-UK
Mar 21, 2002 07:16 PM
