Brass on Oil Pan?
Old Aug 21, 2003 | 12:07 PM
Vtec92Civic's Avatar
Default Brass on Oil Pan?
Can a Barb fitting be welded onto an oil pan, or will that just not work?
Old Aug 21, 2003 | 12:45 PM
mos's Avatar
mos
Default Re: Brass on Oil Pan? (Vtec92Civic)
You can probably braze it on there.
Old Aug 21, 2003 | 01:13 PM
xci_ed6's Avatar
Default Re: Brass on Oil Pan? (mos)
or you could get a 3/4" x 3/4" pipe thread barb ($.75) and a 3/4" pipe thread lock nut ($.35) and drill a 5/8" hole in the pan. Thread in the barb, cover in sealant, tighten down lock nut for safety.
-Dustin
Old Aug 21, 2003 | 02:22 PM
mos's Avatar
mos
Default Re: Brass on Oil Pan? (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">or you could get a 3/4" x 3/4" pipe thread barb ($.75) and a 3/4" pipe thread lock nut ($.35) and drill a 5/8" hole in the pan. Thread in the barb, cover in sealant, tighten down lock nut for safety.
-Dustin</TD></TR></TABLE>
That sounds good too.
Old Aug 21, 2003 | 07:35 PM
Dustin,
So basically get a barb fitting lock nut, and JB Weld or something and just do that? Sounds like it would work . . . I drilled a hole today, and tightened my barb fitting that is 5/8" and was going to JB Weld it right now . . . . guess I should go get a pipe thread lock nut just for safety . . . can't be much maybe $0.50
DrSeuss
Jun 20, 2007 06:34 PM
EJ1 wilcox
11
Feb 16, 2005 08:57 AM
gdrum
Jan 27, 2004 05:58 AM
STAGE 2
Oct 9, 2003 09:47 AM
civictypenos
Mar 9, 2003 07:05 AM
