Need help with Hondata misfire.
Old Aug 21, 2003 | 04:51 PM
Chiovnidca's Avatar
Default Need help with Hondata misfire.
I have an intermittent missfire with my d16z6 with Greddy turbo. Sometimes it's minor, sometimes it's pretty bad. Here's a .rec graph of a bad one. Any ideas?
Old Aug 21, 2003 | 05:29 PM
lazerus's Avatar
Default Re: Need help with Hondata misfire. (Chiovnidca)
it could be your spark plug wires. does it only miss under boost?
Old Aug 21, 2003 | 05:53 PM
Chiovnidca's Avatar
Default Re: Need help with Hondata misfire. (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">it could be your spark plug wires. does it only miss under boost?</TD></TR></TABLE>
It will do it under all conditions, but it's most noticable under boost. I don't think it's ignition related. What would make the injector pulse width go ape ****?
Old Aug 21, 2003 | 06:41 PM
ekb18c's Avatar
what's the gap on your spark plug? Try a smaller gap.
Old Aug 22, 2003 | 02:39 AM
Chiovnidca's Avatar
Default Re: Need help with Hondata misfire. (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">what's the gap on your spark plug? Try a smaller gap.</TD></TR></TABLE>
I tried that.
Old Aug 22, 2003 | 02:46 AM
lazerus's Avatar
Check your spark plug holes for water, and check for arcing through the plug boots.
how did the misfire start?
Old Aug 22, 2003 | 04:08 AM
BoostedsiR's Avatar
I had a bad problem once like that and it was my wires they looked fine but on the inside it was like they were grounded out
Old Aug 22, 2003 | 04:18 AM
PM-Performance's Avatar
Default Re: Need help with Hondata misfire. (BoostedsiR)
mine was backfiring while we were tuning it and having slight blips at like 3800 or so , the backfiring wa sloud like a shotgun , this was when i let off the gas thogh. and the fuel maps were fine . this was tuned on a s200, once we converted the rom over to my 4b everythign worked great.
i think the s series software has some blips to itt whether anyone wants to recognize it or not .
Old Aug 22, 2003 | 05:14 AM
DC2R714's Avatar
Default Re: Need help with Hondata misfire. (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">mine was backfiring while we were tuning it and having slight blips at like 3800 or so , the backfiring wa sloud like a shotgun , this was when i let off the gas thogh. and the fuel maps were fine . this was tuned on a s200, once we converted the rom over to my 4b everythign worked great.
i think the s series software has some blips to itt whether anyone wants to recognize it or not . </TD></TR></TABLE>
I have to agree. Mine still has blips and it backfires. I dont really mind the backfiring its the blips that are just so ****** annoying. Its only in one area 300 mm/hg. I am using S100b.
Old Aug 22, 2003 | 05:15 AM
Default Re: Need help with Hondata misfire. (DC2R714)
see mine alwyas did it on jeffs s series, he can never find anything wrong with the maps, thne we convert it back to my 4b and all the probs are gone.
Old Aug 22, 2003 | 07:40 AM
dabrown's Avatar
Ok, mine is doing the same... I have changed the Gap on the plugs to 30, changed the Rotor,Cap and wires. I get a blip while idling.. I know you guys love the Hondata but it appears that there are known issues that I can't get a response on from the Hondata forum. For instance the alternator voltage issue, where you have to cut the Alt-C wire in order to get the alternator to stay on... If possible hopefully this thread can get some answers.. Thanks..
Old Aug 22, 2003 | 02:14 PM
Chiovnidca's Avatar
how did the misfire start?</TD></TR></TABLE>
It became alot more noticeable after getting rid of the stock exhaust for a 2.5 inch system. It also has a miss at idle. Compression and leakdown tests good. Ive tried all ignition parts with known good pieces.
JDM_SOHC
Apr 30, 2007 02:24 PM
high_revs
Oct 30, 2005 01:01 PM
vg7z
May 16, 2005 09:27 PM
EG6R
Jan 31, 2005 08:38 PM
LAKER HATER
Mar 29, 2004 04:04 PM
