Heat Wrap.
Old Aug 22, 2003 | 05:35 AM
Happyman's Avatar
Default Heat Wrap.
Well on my greddy kit is has one of the rubber hose return lines that you just clamp on. Well it calls to put heat wrap around it(which i did) but the heat wrap hits the block. Do you think the heat wrap will hold up against the block? I mean worst comes to worst I can just cut the block griddle cause thats what it's touching.
Old Aug 22, 2003 | 05:53 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: Heat Wrap. (Happyman)
if my heat wrap can hold up for the past two years wrapped around the turbo manifold and exhaust housing I'm sure yours can hold up to block temps which are generally about 200 degrees cooler than the primary parts of the exhaust system...
Old Aug 22, 2003 | 07:05 AM
Happyman's Avatar
Default Re: Heat Wrap. (stackz)
Thanks for the reply. Btw, what times are you running? Just curious cause I'm going to be running a greddy kit on my d16y8 with 8 psi. AFC Hacked
Old Aug 22, 2003 | 12:57 PM
stackz's Avatar
Community Builder
low 14's and I run the blue box
Old Aug 22, 2003 | 01:16 PM
Infinity_Racer's Avatar
where can you get heat wrap other than online stores?
Old Aug 22, 2003 | 01:37 PM
stackz's Avatar
Community Builder
Default Re: Heat Wrap. (Infinity_Racer)
speed shops but it ain't cheap.
either 1" or 2" wide 50 foot rolls. I got a 1" wide 50ft roll for $60
I think you can get it also from either http://www.jegs.com http://www.summitracing.com or http://www.mrgasket.com (mine was mrgasket heat wrap)
Old Aug 22, 2003 | 01:46 PM
damn...what about the wrap to reflect heat from the a/c lines? i was reading the archives but most of them are through online stores...i'll try and look around locally...
Old Aug 22, 2003 | 03:08 PM
fsp31's Avatar
>>either 1" or 2" wide 50 foot rolls. I got a 1" wide 50ft roll for $60<<
Ack!
http://store.hamiltonmarine.co...ts=10
This is where I got mine. 100' x 2" for $16.99. I used some of the other expensive stuff too for another project. This is *exactly* the same, except that it's not impregnated with that slimy goo that stinks for a month.
mitoplease
Mar 19, 2009 11:29 AM
Civic Racer X 7
Jun 2, 2007 06:03 AM
CO_CReX
Apr 29, 2007 06:44 PM
IntegraMastaz
Aug 30, 2005 08:45 AM
Sprockets
Sep 15, 2003 10:08 AM
