raced my buddies camaro z28... got questions.
ok as most of you saw... I have a b16a hatchback turbo. I am running 5-5.8 psi
I raced my friends z28 and I beat him until I got into 4th he passed me when I was at aboput 105-110 so I pretty much won... but I dont think so. its a stock z28 with the best engine package that chevy offers.. my questions are,
how fast are those cars in the 1/4 I want to know exactly
when I raise the boost to 8 to 9 psi I should beat him I am guessing.. Right?
also at night.. only at night by car will give a small POP out of the wastegate, and the car will hesitate at the same time. wtf? the only thing I can think of is I havent checked timing yet, but I am pretty sure its retarded.
thansk for the help!
Re: raced my buddies camaro z28... got questions. (nigel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nigel »</TD></TR><TR><TD CLASS="quote">but I am pretty sure its retarded.
i'm pretty sure you're retarded.
thansk for the help! </TD></TR></TABLE>
sorry, couldn't resist.
but I don't think this is the proper place for this question.
and for the record, if it's a 98+ LS1, it'll run anywhere from low to high 13's.
93-97 LT1's will run high 13's to mid 14's.
Re: raced my buddies camaro z28... got questions. (Tofurky)
hmmmmmmm i need to go hunting and **** more people off
you might want to post this also in the "kills section" !
Brad
Brad
your friedn cannot drive. because running 5 lbs of boost is NOT going to even break 200 wheel power. so that means you need to win around 10 lbs to beat him. We build a ls motor up and ran 8.5 lbs of boost and barley kept up with one. and that was with a decently build engine too. so think about that.
You car is maybe a high mid 14 sec car now over the 15.1 it "might" pull on agood day with a tail wind stock.
Re: raced my buddies camaro z28... got questions. (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">your friedn cannot drive. because running 5 lbs of boost is NOT going to even break 200 wheel power. so that means you need to win around 10 lbs to beat him. We build a ls motor up and ran 8.5 lbs of boost and barley kept up with one. and that was with a decently build engine too. so think about that.
You car is maybe a high mid 14 sec car now over the 15.1 it "might" pull on agood day with a tail wind stock.</TD></TR></TABLE>
umm..weight can play a huge role. And the type of camaro. And i donno where your getting this high 14s stuff. You can run high 14s with a stock b16a in a hatchback. In a light hatch with slicks i bet 5-6psi from a b16a can run into the 13s easy.
liam
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">your friedn cannot drive. because running 5 lbs of boost is NOT going to even break 200 wheel power. so that means you need to win around 10 lbs to beat him. </TD></TR></TABLE>Untrue someone on the "other" board just put down 200whp and 150 tq to the wheels with 4lbs of boost on a stock B16.
Re: raced my buddies camaro z28... got questions. (liam821)
Just take off your downpipe and you should hit 10psi no problem and your gonna **** your pants from the difference it makes. I was able to stay right next to and edge out a 2002 ss with exhaust lid and intake and that was on 7psi on a drag kit on a b16 in an ek. I took off the downpipe and I hit a full 10psi and this thing ROLLS, tell your friend to run open downpipe and once you get over the noise (and smell) you'll never go back
