where to get vacuum TEE's?
Old Aug 20, 2003 | 07:47 PM
Nextelbuddy's Avatar
Default where to get vacuum TEE's?
all i need to finish my turbo install are the vacuum TEE's and some vacuum lines.. does anyone know where i can buy some? im talkin about the little vacuum TEE fittings so i can hook up my boost gauge and also for me boost controller.
Old Aug 20, 2003 | 07:49 PM
vtec.dc2's Avatar
Default Re: where to get vacuum TEE's? (nextelbuddy)
most auto parts stores should sell them.. i cna't remember what size it should be though..
Old Aug 20, 2003 | 07:53 PM
RenoRacing's Avatar
Default Re: where to get vacuum TEE's? (vtec.dc2)
petco has nice steel tees for 1.49$! No more breaking them when pulling the lines off. i picked some up w/ my check valves!
Old Aug 20, 2003 | 08:33 PM
Default Re: where to get vacuum TEE's? (HavokRacing)
petco? the pet store? so i can use the vacuum tees that tey use for fish tanks?
Old Aug 20, 2003 | 11:38 PM
u2civic1's Avatar
pepboys has them
if no one looking u can steal them
Old Aug 21, 2003 | 01:43 AM
Mr. Softee's Avatar
Default Re: where to get vacuum TEE's? (u2civic1)
ace
Old Aug 21, 2003 | 05:35 AM
quikB18B's Avatar
Default Re: where to get vacuum TEE's? (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">ace</TD></TR></TABLE>
except i think i paid like 3-4 Dollars for one! ACe will also have vacuum line, i paid 49 cents a foot
Old Aug 21, 2003 | 05:59 AM
Happyman's Avatar
Default Re: where to get vacuum TEE's? (quikB18B)
What about ones that have a bigger to a smaller? Like my Vaccum Line for my vaccum manifold is only like 1/4 inch inlet but the vaccum hose im gonna tee is like 1/2" to an 1" I can't really tell. Where can I get one for that?
Old Aug 21, 2003 | 06:10 AM
Default Re: where to get vacuum TEE's? (Happyman)
thanx guys for your help ill check ACE and pepboys today.
i have another question though, there is already a tee between my intake manifold and fuel pressure regulator on my gsr motor because of the secondary butterflies is it ok to go ahead and tee off this again for my blow off valve AND boost gauge? i heard that the more you tee off a source the less accurate or potent the vacuum source gets if this is true then i have no where else to tee off of any suggestions?
Old Aug 21, 2003 | 07:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">thanx guys for your help ill check ACE and pepboys today.
i have another question though, there is already a tee between my intake manifold and fuel pressure regulator on my gsr motor because of the secondary butterflies is it ok to go ahead and tee off this again for my blow off valve AND boost gauge? i heard that the more you tee off a source the less accurate or potent the vacuum source gets if this is true then i have no where else to tee off of any suggestions?</TD></TR></TABLE>
bump
Old Aug 21, 2003 | 08:52 AM
IN VTEC's Avatar
Lowe's or Home Depot. They have brass and nylon barbed tee's fittings.
bads2k
Nov 26, 2009 01:38 PM
EVOCELICA
May 3, 2004 07:27 PM
5thgencivic
Nov 19, 2003 11:12 PM
InTeGrA B18b1
May 11, 2003 10:08 PM
Westsideboy
Apr 19, 2003 05:21 PM
