cartech FMU question
Old Aug 22, 2003 | 04:21 PM
BoostedITR41's Avatar
Default cartech FMU question
which way do you turn the **** for a 12:1 setting? is it like a FPR and all the way in is the highest setting?
Old Aug 22, 2003 | 04:41 PM
swrdply400mrelay's Avatar
Default Re: cartech FMU question (BoostedITR41)
The top **** adjusts the fuel pressure at 0psi so you can tune for a smoother transition into boost. The side **** is what adjusts the fuel to air ratio (the disc ratio). I don't know how to tell you to adjust it to the right ratio other than to take it to the dyno and play with it until you get a good fuel to air ratio. You turn it clockwise to raise the ratio higher, and loosen it (counter clockwise) to lessen the ratio.
Old Aug 22, 2003 | 04:57 PM
Default Re: cartech FMU question (swrdply400mrelay)
thanks....that is what I thought but before I started turning ***** I wanted to make sure I had it right
SMOOTH97LUDE
Sep 20, 2003 05:27 PM
RNPoo7
May 7, 2003 03:24 PM
BoostedD15B7
Apr 22, 2003 05:55 AM
BoostedD15B7
Nov 11, 2002 11:41 AM
TURBOED-TEG
May 1, 2002 10:28 AM
