880cc injectors/hondata
Old Aug 21, 2003 | 03:34 PM
B18C1_T's Avatar
Default 880cc injectors/hondata
Has anyone on Honda-tech run 880cc injectors with hondata? if so any problems?
Old Aug 21, 2003 | 04:12 PM
PM-Performance's Avatar
Default Re: 880cc injectors/hondata (B18C1_T)
from what boosted hybrid told me 880's should idle like stock as long as its tuned right, anything getting real clsoe to 1000cc's though start to get shaky.
Old Aug 21, 2003 | 04:22 PM
uglyasscivic's Avatar
Default Re: 880cc injectors/hondata (itr206)
They should be cake as long as they are good injectors. I like the new precision injectors
Cort.
Old Aug 21, 2003 | 04:27 PM
Chamois's Avatar
Default Re: 880cc injectors/hondata (uglyasscivic)
Cary (cheezefrog) runs 880's w/ hondata; the only reason his car idles like *** is because of his cams. All you need is the injector resistor and a decent tune.
shami
Old Aug 21, 2003 | 04:47 PM
333's Avatar
333
Default Re: 880cc injectors/hondata (Chamois)
I have 720cc and Hondata. Idles at 800 rpm easy. trying to boost 22psi.
Old Aug 21, 2003 | 05:40 PM
ladysman's Avatar
Default Re: 880cc injectors/hondata (333)
I run 800's and it idles like stock.
Old Aug 21, 2003 | 05:44 PM
Turbocivic94's Avatar
I run 880's with hondata, no problems
Old Aug 21, 2003 | 05:51 PM
B18C1_T's Avatar
thanks honda-tech peeps now i just got to order them in now from arturbo
Old Oct 18, 2003 | 02:39 PM
g2turbo's Avatar
Default Re: (B18C1_T)
what whp will 880's support if i keep the factory regulator(and pressure) with hondata? I was running 550s and now i need something that will support over 500 on stock fuel pressure. I was planning on running 1000cc injectors but havent heard a whole lot of people idling them well. any more info.
Old Oct 18, 2003 | 02:48 PM
FredoSP's Avatar
will the precision injectors fit a STR fuel rail?
Old Oct 18, 2003 | 02:52 PM
g2turbo's Avatar
Default Re: 880cc injectors/hondata (FredoSP)
i would think so if they are machined to fit a factory honda rail. not sure though
Old Oct 25, 2003 | 08:17 PM
B18C1_T's Avatar
yup they fit fine
Old Oct 25, 2003 | 11:47 PM
V-SPEC 1's Avatar
Default Re: (jerseykid609)
will the 1000cc with hondata idle bad? or can it be tune to idle close to stock.
Old Oct 26, 2003 | 05:56 AM
GruvyTune's Avatar
New User
will run like stock with proper tuning
Old Oct 26, 2003 | 06:40 AM
ladysman's Avatar
Default Re: 880cc injectors/hondata (GruvyTune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GruvyTune &raquo;</TD></TR><TR><TD CLASS="quote">will run like stock with proper tuning</TD></TR></TABLE>
Lokar
Apr 4, 2004 08:20 PM
95ONE
Mar 3, 2004 07:41 PM
Diego Boost
Feb 26, 2003 11:10 AM
ALLMOTOR18
Jan 30, 2003 04:25 PM
kuya kanin
Oct 2, 2002 06:28 PM
