Lst Build Questions
Lst Build Questions
Hey H-t,
b18b1 with hyrdo tranny 80K on both
Pieced together Turbo kit(no ebayjunk)
440's(RC)
GARRET T3/T4 60 trim
Custom made exhaust manifold
Custom downpipe
Custom made vacume box
After Engine is built and all together Heading to.. Babylon ,N.Y -NRG Tech
Gunning for 300 whp at the dyno
Full oem Honda gasket/seals
Moroso baffled oil pan
Might Throw a B20 head On it For alittle more top end as the valves are a bit bigger what do use think?
Question for you gearheads..
What pistons and rods Should i buy?And what size pistons Standard?
What compression ratio i should go with?
I wanna blockgaurd the sleeves can a machine shop do this for me?
Or is it a DIY Project.
Spread your knowledge!!
440's(RC)
Custom downpipe
Re: Lst Build Questions
idk why i quoted my own quote(zoooted) but i forgot to mention does anybody use the "GM" map sensor?? where do i grab one of the bad boys lol
nicee so i can use my stock map cuz im only ganna run 7 pounds and i know how to drive a high boosted DA integra so i wont be beatin this up much at all maybe a couple pulls on the high way thats all
