random head gasket question
Old May 25, 2011 | 12:43 PM
sh!ft's Avatar
Who the fack changed my title?!
Default random head gasket question
if im 81.5 and i need to get a head gasket, do i buy one for 82mm? the tech at cometic said to do that. i will possibly be purchasing their hybrid series head gasket if i can get any responses soon.
Old May 25, 2011 | 01:07 PM
guy_from_nerk's Avatar
Default Re: random head gasket question
No you buy the gasket to match your bore. Apparently Cometics customer service/tech department is as shitty as their gaskets. Buy an OEM or get one from Golden Eagle. My cometic lasted 952 miles before I had to replace it due to it leaking oil out between my head and block, put a golden eagle (oem) gasket in there, and leak be gone
Old May 25, 2011 | 01:11 PM
sh!ft's Avatar
would make sense. i already got their dowel pins.(shrugs/sighs) might as well pay the extra 30 bucks for reliability.
Old May 25, 2011 | 01:21 PM
Exactly, I wish I would've went Golden Eagle from the get go, oh well live and learn
Old May 25, 2011 | 01:23 PM
sc34dc4's Avatar
I'm 81.5 and just run the oem honda gasket. Works great.
Old May 25, 2011 | 01:35 PM
sh!ft's Avatar
my block has been decked and some **** has been taken off the head. still suggest doing it?
Old May 25, 2011 | 01:37 PM
alperx's Avatar
yes - go with the OEM.
Old May 25, 2011 | 01:40 PM
sh!ft's Avatar
ok so assuming this is a gsr head i should match the gasket to the head. ok, cool.
Old May 28, 2011 | 12:12 PM
sh!ft's Avatar
well wait, do i match the gasket to the head or the block? ls or gsr? need to know ppl!
Old May 28, 2011 | 10:55 PM
Bond's Avatar
I suggest you read this link.
http://www.goldeneaglemfg.com/includ...yGEMgasket.jpg
To give you an easy answer, match the gasket to the head when building an LS/V
Old May 29, 2011 | 12:37 AM
MR.johnson's Avatar
Get .5 over your bore. I learned the hard way with cometic. Golden eagle and be done with it.
Old May 31, 2011 | 03:11 PM
sh!ft's Avatar
ok 82mm itll be then! lol thanks guys
strigga
Sep 28, 2018 05:58 PM
Muckman
Apr 6, 2018 11:25 AM
Eghatchgsr8
Sep 19, 2014 02:24 PM
Joeski99Si
Apr 23, 2009 05:24 AM
westcoaststyle
Jun 11, 2004 05:51 AM
