water temp to high ???help
Old Jun 22, 2011 | 12:40 PM
TURKISHFORCE's Avatar
Default water temp to high ???help
hi from berlin..
is this water temp normal ok for a smal oem halfsize radiator cooler
when i start goes the water temp to 80 C grad (then after 10 minutes it goes to 92c grad , and when i drive slow under 3000 rpm ist goes to 210 f - 98 grad.
last when i drive over 4000 rpm it goes to 220f 102-105 c temp
i have change neu termostat/neu glysantine 50/50/radiator ist neu??
can i drive in this temp level ore is this to high ??
Old Jun 22, 2011 | 08:04 PM
EsotericImage's Avatar
Retired Moderator
Default Re: water temp to high ???help
anything over 210F is too high..
Try a better fan!
http://www.xenocron.com/maradyne-13-...a2b52c08ef77e0
Old Jun 22, 2011 | 11:24 PM
rich7777's Avatar
You really like that fan don't you ? I've run it in the past to with good results.
Old Jun 22, 2011 | 11:28 PM
eg6bpd's Avatar
Originally Posted by TURKISHFORCE
hi from berlin..
yeah bro thats not a good sign,you should definetely check if ur fan is working,and i suggest you check out your engine gasket cause theres a big chance ,with that kind of heat it shouldnt be in the best condition
Old Jun 23, 2011 | 03:55 AM
my tuner has any modification bad, not enough place for a big radiator?? ****
the downpipe exaust is so close from the water cooler radiator..
Uploaded with ImageShack.us
friend told me to check gasket?
result is. 9 bar compression test
no water loss, no white smoke
no hp loss, but the upper radiator hose is very hard ,and on the top of the cooler caver is litle gray gream??the water is litle color oily??
and i install the radiator not weird,skewed ,to close the motor hood
is the radiator cooler to smal ore the gasket head blown..
how can i get right gasket check?
i use high compression with bad big 3mm gasket?
Old Jun 23, 2011 | 04:41 AM
th3pwn3r's Avatar
Dude you're BOILING the water through conductivity. That radiator looks like it's a great heatsink as it sits. Is there any way you could move it? At least you have a filter on that turbo.
Old Jun 23, 2011 | 12:02 PM
civickiller's Avatar
When's the last time you changed the water pump?
Have your tuner lower the fan temp and drill holes in the thermostat
Old Jun 23, 2011 | 10:14 PM
water pump is new, maybe i use too much from this product (bars gasket fixed)
and other **** like radiator leaky fixed..
and the water systeme passage is blocked with this sticky stuff???
i will first clean rinse the water systeme?
and no holes on the thermostat ,the radiator fan start at 209 f 98c
Old Jun 23, 2011 | 10:32 PM
Retired Moderator
fan should kick on at 180*F but drill holes in the thermostat like said ^^
dumptube should not be that close to the radiator. find another route for the dumptube.
Do not use those bars-leaks products as they do more harm then good. Fix whatever is leaking. This is key to keep everything working normal.
Dr
Old Jun 24, 2011 | 01:26 AM
I hear for the first time,?
how big hole and where
google pictures
http://www.gessford.com/cobraparts/Thermostat-08254.JPG
http://i26.photobucket.com/albums/c1...dstatx1600.jpg
Old Jun 24, 2011 | 04:30 AM
fcluddington's Avatar
Dont waste your money on a cheap fan. Get a spal with a shroud lots of HT vendors have them T1 is one and look at the radiator, fan, and shroud they sell. The fan referenced above pulls 1/2 the amount of air that a Spal it's size will pull. it also costs 1/2. You will also have to look into running new wiring for the fan as they are 30 amp rated. Also look into articles on creating ducting to direct air that isnt heat soaked from the intercooler/ ac condensor. A turbo blanket and wrap the cast iron log. GL
Old Jun 24, 2011 | 07:09 AM
but i can just use a smal spal fan size like 26cm 25cm fan, and makes the smal fan air power enough?? ore i thinks is the same power like oem fan from ef9?
example photo
sorry for the bad wastegate place , my tuner is a mokey ...
Old Jun 25, 2011 | 12:53 PM
i clean first the water system and buy a new fast slim radiator fan.
Old Jun 26, 2011 | 07:11 AM
when goes the radiator fan on start (ef9-ee9 b16a1)
and when goes the oem temp gouge over the medium mitle center display?
my temp needle is under the middle when i drive , never goes over the midle display..
the china gouge is maybe **** defect rong result..
nicanbeastfool
Aug 20, 2014 10:04 AM
MPALUGHI
Aug 15, 2005 12:49 PM
VTECisSeXY
May 31, 2005 05:32 PM
Albino Dragon
Apr 18, 2002 10:15 PM
