View Poll Results: What Should i use?
Voters: 15. You may not vote on this poll
Need advice! Oil restrictor on my Precision Turbo SC44?? Use one or not?? PLZ HELP!
I am turboing my car, i want to make 300-350 hp.
I have a ported oil pump. My motor is a d16z6, fully built.
Im using a Rebuilt Precision SC44 Journal Bearing
Compressor Cover T04E 3" Inlet
Exhaust Housing T3
A/R .63
Exhaust Trim 63
My question is, has anyone used this turbo?? I have been searching around on people using oil restrictors due to their seals blowing.
My questions are
Do i need a oil restrictor?
What size oil feed line should i go with?
What oil return line should i go with??
My research-
Using a -3an feed no restrictor?
Using a -4an feed no restrictor?
Using a -3an Feed with .65" restrictor??
ANY ONES ANSWERS WILL BE HELPFUL!
Please reply or answer to the poll please!
Exhaust Housing T3
A/R .63
Exhaust Trim 63
My questions are
My research-
Re: Need advice! Oil restrictor on my Precision Turbo SC44?? Use one or not?? PLZ HEL
-3 no restrictor is fine. ball bearing is where a restrictor should be used.
call them, know what your min and max oil pressure is.
Moderator
at Cold start and WOT if known. Anything over 80psi of oil pressure at either of those points, use no smaller than a .060 restrictor on your -3AN line.
Unfortunately, you will get conflicting information from Precision directly, because they don't look at the engine application closely enough to have a general idea of what the oil pressure is at that 2 main points. What works for Mitsu, may not work for Honda, or Subaru which uses very high oil pressures..
so on a b18c you're saying to use a -3 and a .060 restrictor or just a -3 or a -3 with a .060 or larger?
precision just says a -3 but i also wondered about this since a stock ITR for example has some pretty hardcore oil psi, especially when cold
Moderator
i'm curious about this too and will do whatever you tell me to on this one.
RULE OF THUMB .... If oil pressure is over 75-80psi at cold start and WOT, use restrictor of .065 or .060 REGARDLESS OF FEEDLINE SIZE. IT JUST MEANS WHAT YOU HAVE MAKES TOO MUCH OIL PRESSURE
Guys, I can't reiterate this enough. PLEASE GO BY THE OIL PRESSURE OF THE TURBOCHARGER AND ENGINE ON AN INDIVIDUAL BASIS. THIS IS NOT A ONE SIZE FITS ALL SOLUTION. ;-). IF NOT SURE, TRY WITHOUT ONE FIRST, THEN USE ONE IF NEEDED. ;-)
If its run for a short period of time and pushes oil past the oil rings and then you instal a restrictor then it should be fine, if its ran for a long time pushing oil then most likely will need new oil rings. the oil rings are only designed to handle a mximum pressre of 65psi and just about all hondas at cold start up and wot push 70+ psi oil pressure. I've been running a restrictor .065 on my garrett turbo for years, works like a charm
(Oh, and I'm not voting for the same reason TheShodan said -- don't know enough about how everything is going to work out with your setup. I think a little trial and error may be necessary)
