Sending bottom block out, need advice
Old Jun 16, 2011 | 11:01 AM
guess_who's Avatar
Default Sending bottom block out, need advice
Hello all,
I'm sending my bottom block out to Mike down at Laskey Racing and need some help choosing internals. I'm thinking of choosing some pistons a with a little higher compression than 9:1 but not too much higher (9.5:1-9.8:1 area) Also need help choosing between Pauter or Manley rods. I've chosen not to go with Eagle due to me wanting to rev high and have peace of mind. So here are some build notes.
Cliffs:
83mm or 84mm Benson sleeves (haven't decided bore yet)
9.5:1 CP pistons
GSR crank (Might go get a LS crank from the junkyard if I'm not lazy lol)
ACL Bearings
OEM (TypeR) oil pump
Lower gasket set
Blueprint and assembly
Looking for 400-450 hp on 91 for the street and around 600 on E85.
Discuss.
Old Jun 16, 2011 | 11:40 AM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
Default Re: Sending bottom block out, need advice
84mm
either rod
ls crank
Old Jun 16, 2011 | 11:41 AM
guess_who's Avatar
Any suggestion on a compression ratio?
Old Jun 16, 2011 | 12:00 PM
UJLSMoFo's Avatar
9.5 - 9.8
Old Jun 16, 2011 | 01:09 PM
CDecker0218's Avatar
83mm (leaves room for error)
9:1 CP's
Manley Turbo Tuff Rods
LS crank
Old Jun 16, 2011 | 02:01 PM
guess_who's Avatar
If I don't go to the junkyard and get one will it make that much of a difference between the GSR and LS crank?
Old Jun 16, 2011 | 02:08 PM
guess_who's Avatar
Forgot to mention, this car will be somewhat of a DD with a good amount of track time.
Old Jun 16, 2011 | 02:21 PM
sp00led's Avatar
Mike built my motor. Started at 83mm GSR and after an incident I'm at 84mm. I went with 9:1 CPs and Pauter rods. I've got about 15-16k hard miles on a GT30R setup making 550whp.
Old Jun 16, 2011 | 02:42 PM
UJLSMoFo's Avatar
leave room error, im comfused? anyway you go, the hp goal your looking for want be hard to acheive with parts.
Old Jun 16, 2011 | 03:11 PM
guess_who's Avatar
I think I'm gonna go with a 83mm just in case something happens (which I hope not) Are you using a LS crank? If you could do it again would you raise your compression ratio?
Old Jun 16, 2011 | 03:15 PM
guess_who's Avatar
Well, if I have a 83mm bore and something happens and I have to rebuild, I can bore to 84mm and not have to worry. If I have a 84mm bore and something happens and I have to rebuild and bore to 85mm, high boost would not be safe due to the walls being thin? But if the block is sleeved cant I still boost pretty high and not have to worry with a 85mm bore?
Old Jun 16, 2011 | 03:18 PM
sanman000719's Avatar
man most of us guys are running more than 10:1 on e85
also to be honest the stock block will make the power you see, and if you want to feel safer just do internals on the stock sleeves
Old Jun 16, 2011 | 04:22 PM
guess_who's Avatar
E85 is kinda far from me. I'll get it if I have to though. As far as sleeving goes, I did save up the extra money for it so I might as well do it at this point.
Old Jun 16, 2011 | 04:41 PM
UJLSMoFo's Avatar
83mm it is then, good luck.
Old Jun 16, 2011 | 05:12 PM
good luck with it man
and just order e85 by the drum, and you will be good to go
by the way find a great tuner that good with e85, and this will be even better
Old Jun 17, 2011 | 08:21 AM
sp00led's Avatar
I used a GSR crank. I would not raise the compression if I did it over again. 9:1 is working out for me great. With a GT30R once you hit that 0psi mark the car starts to pull even at part throttle in the city.
The only thing I would do over again is probably ditch my Full-Race AC setup as cooling with a half sized radiator in an integra just isn't very realistic for 95-100F temps or circuit racing.
I even had my fuel pressure regulator vac line come off once so I wasn't raising pressure with boost. It leaned out and detinated on me but that was like 5k miles ago and the compression is still perfect.
Mike/Benson put together some stout blocks!
Old Jun 17, 2011 | 08:40 AM
are you on e85???
Old Jun 17, 2011 | 10:48 AM
guess_who's Avatar
My set up will be going into a DC as well. I'm not to sure what I'm going to be doing cooling wise just yet. I want to get the motor in and see what my options are at that point. I'll be using a Lovefab ramhorn with a 46mm wastegate so I'm pretty sure I'll have to use a half sized radiator.
Old Dec 12, 2011 | 10:56 PM
AllMotorKiDD's Avatar
FAGGOL!!!!!upgrade fuel pump pronto.will give out of u if u run e85 and go boost crazy
carlossolorzano
May 27, 2012 01:12 AM
haas480
Sep 1, 2009 04:09 AM
9db85
Jun 22, 2007 08:08 PM
gmacarize
Jul 31, 2006 08:56 PM
