Garrett 4 bolt pattern...
Old Jun 10, 2011 | 01:44 PM
ryguy2588's Avatar
Default Garrett 4 bolt pattern...
Hey guys,
I was wondering if the 4 bolt pattern on my .63 ar gt30r turbine housing is the same bolt pattern on the .63 ar 4 bolt pattern on my 57 trim turbo? I want to run the gt30r but if I end up using the 57 trim, will I have to change the downpipe? They have the same diameter and same threads but I was wondering if the bolt pattern might be clocked differently?
Old Jun 10, 2011 | 04:59 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Garrett 4 bolt pattern...
as long as you dont have the "optional GT housing" then yes they should be the same.
Old Jun 10, 2011 | 05:16 PM
ryguy2588's Avatar
This is the housing I bought.
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
It's not the one that is extended and tapered to 3" outlet.
Old Jun 10, 2011 | 05:36 PM
TheShodan's Avatar
Moderator
That's correct. The housing that your 57 trim uses is a T31, as is the one you just ordered. You'll be fine for fitment.
Old Jun 10, 2011 | 06:33 PM
ryguy2588's Avatar
Great. Thank u guys so much!
TateEvan
Jan 16, 2012 08:15 PM
TurboEM1
Oct 1, 2006 05:59 PM
StreetEG
Jul 27, 2006 06:21 PM
H22coupe
Nov 20, 2002 01:59 PM
