boost drop off
Old May 24, 2011 | 04:43 PM
hondatuner020's Avatar
Default boost drop off
Basically im hitting full boost of 13lbs on my 5431b and it is tapering down to 11 by redline... it also tapers down slightly lower when doing back to back pulls, leading me to think there is a heat related issue... i have no vacuum leaks or exhaust leaks.. is my wastegate the cause of this?
b18c1
inline pro log
precision 5431b
3 inch dp back
tail 38mm 10lb spring
hks ssqv
precision 650cc
neptune
manual boost controller
Old May 24, 2011 | 07:04 PM
MR.johnson's Avatar
Default Re: boost drop off
what type of boost controller do you have? how do you have your WG vacuum lines ran?
Old May 24, 2011 | 08:19 PM
mtber's Avatar
Eliminate the boost controller & run the car on the wastegate spring.
See if the issue occurs on the spring pressure only.
Old May 24, 2011 | 08:32 PM
97CWITR's Avatar
Can you post pics of the setup, and a graph.
Want to put together a very similar setup and want to see the fitment.
Thanks!
Old May 24, 2011 | 10:27 PM
a line is ran from the compressor housing to the manual controller to the wastegate
Old May 25, 2011 | 09:13 AM
MR.johnson's Avatar
What type of controller... Have you bypassed it?
Old May 25, 2011 | 05:02 PM
http://www.xenocron.com/manual-boost...ler-p-267.html
im getting my dyno info from the wastegate spring pulls to see if it faded on them. i should have them tomorrow
Old May 26, 2011 | 09:52 AM
i took apart the wastegate, and the diaphragm and spring are in great condition, but is where im getting confused, the spring in it was the large green spring, which is supposed to be 13.05 psi, how were we able to do runs on 10psi if it is a 13psi spring? the car has always had the boost controller hooked up, we have never run it with a line straight to the wastegate. is there someway the boost controller was able to make it run 10psi? im very confused now.
Old May 26, 2011 | 10:08 AM
kyden's Avatar
i imagine pressure loss through the system (although 3 psi is a bit much)
Old May 26, 2011 | 11:11 AM
i was told that back pressure in the short log manifold could make the 13psi spring open early...
Old Aug 10, 2011 | 08:04 PM
nsk crx's Avatar
at what rpm are you getting full pressure?
slowhonduh93
May 20, 2007 09:34 PM
adamsjm5
Sep 15, 2005 06:18 PM
ek9vboi2
Jul 18, 2004 08:14 PM
shingles
Jan 24, 2003 01:58 AM
vtec.dc2
Dec 28, 2002 08:03 AM
