LS/VTEC overheating or normal
Old Jun 4, 2011 | 12:44 AM
alperx's Avatar
Default LS/VTEC overheating or normal
I have a ls vtec freshly built with a half-size aluminum radiator and slim fan.
The thing is : the temp comes to 212 F when on highway after 20 minutes of driving and stays somewhere there. the fan works but doesnt seem to have much effect.
when I just had the LS with the same radiator, there was no such problem and the car never hit 200 F on highway driving.
What can be the problem ?
Old Jun 4, 2011 | 02:18 AM
Annihilator's Avatar
Default Re: LS/VTEC overheating or normal
did you try replacing the thermostat? That's a pretty dangerous temperature to be cruising at...my car goes in to limp mode if it crosses somewhere around 205*
If the thermostat is ok, maybe try a quick compression test to see if your HG isn't leaking. I personally wouldn't drive it like that for long...might warp the head if it creeps up much higher.
Old Jun 4, 2011 | 11:41 AM
civickiller's Avatar
is the bottom end block the same ls bottom end block you were running before?
I would think thermostat, water pump, or radiator and I would change them in that order. Make surefan is spinning the right Way with the blades
Old Jun 5, 2011 | 10:59 AM
alperx's Avatar
the bottom end is the same..
I changed the thermostat, it's the same..
my headgasket is from the Golden Eagle ls vtec kit, and there isnt a leak..
I'll try the water pump..
the fan also sucks..
is it OK if I put another fan from the front ?
Old Jun 5, 2011 | 02:15 PM
94GSRMR's Avatar
my car tries to overheat too, 94integra. the car can idle in 72+degree weather and will fluctuate from 179-182(fan kicks on then goes back to 179) and never overheat, but if after letting it idle and get in it and drive it up the road for about 9 minutes itll reach 220 then i would have to bring it home and let it idle then the temps will drop?
Old Jun 5, 2011 | 10:37 PM
The fan sucks, are you mocking it or does the fan pull air sucking it ?
Are you sure it's not wired backwards? Or the blades are backwards?
Old Jun 6, 2011 | 03:59 PM
blackeg's Avatar
i was having an issue last year similar to yours. hre are the bunch of quick things i did to help( and it has too it was 86 outside today and my coolant stayed put on 194.
heatwrapped manifold and downpipe
propped the back of the hood up a bit with some washers to let some hot air out
drilled four 1/4" holes in the thermostat.
all have worked like a charm
Old Jun 6, 2011 | 04:08 PM
VRD^don's Avatar
put the stock fan back on with the shroud, if it doesnt call for a slim fan then put your stocker back on. a fan with a shroud will cool better than a 10-12 slim fan with out one.
Old Jun 6, 2011 | 09:20 PM
EsotericImage's Avatar
Retired Moderator
Had the same problem, but not as hot as yours. Bought this fan and all my hot temps worries went away.
http://www.xenocron.com/maradyne-13-...c2d66717a90f68
Old Jan 3, 2020 | 03:09 PM
EKmazter's Avatar
For ls vtec do i use a ls thermostat or a gsr thermostat?
Old Jan 3, 2020 | 08:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It is the same part number. 19301-PAA-306
turbo-crx
Jun 11, 2008 09:53 AM
xxthabest1xx
Nov 14, 2006 07:47 PM
JODYG35950
Nov 2, 2005 08:26 AM
SprayinCX
Mar 23, 2004 08:51 AM
made in JAPAN
Mar 15, 2003 11:31 AM
