Problem with ITR/JRSC
Old May 28, 2011 | 06:44 AM
thedon67's Avatar
Default Problem with ITR/JRSC
Hello, I'm new to the tuner world and ran it to a small snag. I recently purchased a 98 ITR with a JRSC. In order to pass emissions testing, I had to switch out the 440 fuel injectors and the Hondata300 back to the stock units. All was fine, passed inspection. I just put back on the 440s and Hondata ECM and now the idle is all messed up. When I start the car up it is idling at 1900 rpms. If I kick it down, the idle now pulsates from 1100 to 1900. The car seems to drive fine, but obviously, I did something to it.
Any suggestions on what I need to do to correct would be most appreciated. Thank you.
Old May 28, 2011 | 02:16 PM
Jaker's Avatar
Default Re: Problem with ITR/JRSC
Vacuum leak at the injectors.
Old May 28, 2011 | 02:34 PM
cibao2ner's Avatar
take out injectors and put a lil silicone around the rubber rings that they sit...also remenber to lube the injector o-rings with oil cause they break and leak fuel...
Old May 28, 2011 | 03:34 PM
thedon67's Avatar
I'll give it a try. Thank you!
I did put on new OEM Honda O-rings. I also bought new OEM seat rings but didn't put them in becuase they were only half the size of the seat rings that were in there. Now I'm thinking maybe I should give them a try.
Old May 28, 2011 | 04:35 PM
racebum's Avatar
absolutely a vac leak somewhere, as said the injectors are suspect
Old May 29, 2011 | 12:47 AM
MR.johnson's Avatar
Start it. Spray brake clean at injectors. Listen for engine to idle down. Leak found.
Old May 31, 2011 | 08:40 AM
thedon67's Avatar
Well you were right. It was a leak at the injectors. Now that I put the new seat rings in and tightened down the fuel rail, the car runs like a champ.
Thanks for your help!
nextproject97
Apr 22, 2009 04:43 PM
92TEGsrSC
Jul 7, 2003 09:16 AM
B_1_8_hatch
May 1, 2003 03:07 PM
SlowAutoLS
Mar 27, 2002 05:47 PM
