turbo spec help
Old Jun 17, 2011 | 11:59 AM
civic-steve-94's Avatar
Default turbo spec help
do anyone have any information on this turbo i think its a aircraft turbo
it a garrett t4 and it says a/r 60 on inlet housing and a/r 69 on exhaust housing
can anyone tell me like boost or what kinda a power i can expect out per psi
i wanna get like 450whp at about 18psi on my b16 stock bore stock stroke
i have 9.0:1 supertech pistons with ferrera flat faced valves so i dont know the true compression ratio
Old Jun 17, 2011 | 12:18 PM
TheShodan's Avatar
Moderator
Default Re: turbo spec help
You must put forth the effort to deal with your purchase that you knew nothing about. The only way to know even a remote idea of this turbocharger's capabilities are to
1) take more photos of the turbocharger at both the compressor and exhaust housings and wheels.
2) Take measurements of the turbocharger's inducer and exducer sizes on both the compessor wheel and exhaust wheels (there are diagrams on what to look for.. you will more than likely need to remove your housings in order to do so).
3) don't worry about the PSI so much. Since you were unable to understand the specifications of your purchase, you'll need to get your expectations out of the way, and either deal with what power the turbo gives you, or get another one entirely.
Unfortunately, this is what happens to those who are too worried about the great deal to save money, but have no idea what it is they purchased. (this is only an inference as 90% of the cases that involve your question are based upon this situation. If this does not fit your situation, my apologies.)
Once we have that information, we may be of better help to you.
Old Jun 17, 2011 | 12:53 PM
MR.johnson's Avatar
lol. when i read the title i was going to post "wait for theshodan"
Old Jun 17, 2011 | 01:20 PM
you are a very helpful individual mr.theshodan i will attempt to measure and provide better information
but i pulled this turbo off my friends sr20 after it helped in its demise along with the people that build the car
Old Jun 17, 2011 | 02:15 PM
ok here are some more pictures but i couldn't get the bolts out of the exhaust housing
the exit on the housing measured 69mm
Old Jun 17, 2011 | 07:59 PM
bump
Old Jun 17, 2011 | 08:34 PM
AllShowNoGo727's Avatar
In for more info i know some one on here know's what this thing is.
Old Jun 18, 2011 | 01:45 AM
thanks for that
Old Jun 18, 2011 | 04:36 AM
TheShodan's Avatar
Moderator
Oh hohoho. Just by removing the covers I can tell that this is a much smaller very old design double bladed wheel and tangential housing. This came from a smaller tractor or even a combine. This was a wheel that was made for low speed, larger torque, diesel applications. (This isn't even close to anything in the HX series of a Holset, so guys before making comments, realize that the HX series is a different animal completely.)
No 450whp on this thing, not even remotely close.
Old Jun 18, 2011 | 11:53 AM
thank you for the information could you recommend me a turbo that would put me in that power range
the sr20 that this turbo came off of pulled 336whp@18psi on a crappy tune
Old Jun 18, 2011 | 02:33 PM
TheShodan's Avatar
Moderator
And a low flowing cylinder head (all SR20DETs are like that).
List your budget (maximum willingness to pay for a turbo), flange type, bearing type (Journal or ball-bearing), use of the car. Although you listed a power output... put that output into perspective..(what fuel do you want to make this power? Do you want more later? What is the engine setup you have.
Please don't use an E.T as an example, or a "as cheap as possible while making the most power at XXpsi of boost pressure". Doesn't help. be realistic on what you plan to tune with as well as make sure you have the supporting mods to make the power you want.
Once you do that... PM me
titosek4
Sep 23, 2009 02:13 PM
csubucky19
May 19, 2009 12:22 PM
taggart_lumpy
Feb 16, 2007 11:13 PM
pane93civhb
Aug 9, 2006 01:27 PM
webber17
Mar 8, 2005 10:25 AM
