tuned ecu?
Old May 24, 2011 | 06:30 PM
B16a_delsol94's Avatar
Default tuned ecu?
ok so i finally figured out my car wont start cause i have a bad ecu. my car has a tune on it but im not sure what for cause i just bought the car. anyways its running 5 psi and i have 450cc injectors and i was wondering if i need to get a ecu specifically tuned for 5 psi or if i can just get an ecu tuned for the injectors cause theres one in the area for cheap thats tuned for 450cc injectors. any help would be appreciated thanks.
Old May 24, 2011 | 06:48 PM
92redhatch's Avatar
Default Re: tuned ecu?
In the engine management and tuning section of the forum they have a tuner directory. Call a Honda tuner in your area. If the ecu is tuned for your car then most likely it has a chip in it and all you would need to do is take out your chip and put it in the new ecu( if your new ecu has been setup for chipping). Hope it helps but most importantly call a Honda tuner in your area
Old May 24, 2011 | 06:55 PM
MR.johnson's Avatar
dont use a mail order "map" every car in is not the same. use a good tuner. dont cheap out, tuning is the most important for any car to run right.
Old May 24, 2011 | 09:04 PM
turbohatch96y7's Avatar
Yup take the ecu to a tuner they can give you a new ecu and just swap ths chips over it will cost like 50 bucks to set then new ecu up for the ability to rwmove and replace the zif chip
EF_b- Series
Jul 5, 2007 12:22 AM
b18c-1
Nov 20, 2005 10:14 PM
