help with my build
Old Jun 9, 2011 | 01:45 PM
ferrarisp108's Avatar
Post help with my build
so igot a 1991 honda crx si that i bought for 800 dollars. it is in emaculate condition except for a few minor dings oh well lol. i want to rebuild the motor to handle about 3-400 whp. i am wanting to turbo the engine stock and i have read that it can handle anywhere from 180 hp to 220 hp on stock internals. i dont want to blow the hell out of my engine and not have a car to drive. i just want to know if i could get a turbo that i could use at around 6-8psi of boost on the stock motor and than when i rebuild it swap it out and use about no more than a max of 20psi if possible. the motor is a d16a6 btw. i have done alot of research but not really came to a good answer to this i hope that you can all help me with this!!
Old Jun 9, 2011 | 05:53 PM
SovXietday's Avatar
Default Re: help with my build
Nonvtec motor will hinder you're ability to reach your final goals, the heads just don't flow well enough without VTEC. It makes a big difference.
Your turbo sizing will be the factor for psi that you need to run to make xxx power.
The engine will be ok if you tune it correctly and have a solid setup with proper fuel.
It's really just a matter of doing the research and having faith in your tuner and your build. The car will do the rest.
Old Jun 9, 2011 | 07:12 PM
civickiller's Avatar
U can boost it at 8psi but u need to have it correctly tuned
u can run 400 hp but the block has to be built to handle it
Old Jun 9, 2011 | 07:26 PM
k cool thanks guys. so now i was wondering what you guys would think would be best for a turbo. i hear put a t3 on, but i was not sure if it will boost well at 6-8 psi and i am looking to make about 180 hp on the stock motor. the guy said that he had the top half rebuilt and engine is in good condition. and like i said down the line i will be rebuilding everything from the ground up. and i dont really have a budget i will save however much but hoping not to go over 4-5 grand.
mykulangot92
Dec 3, 2010 06:00 PM
steelermike27
Feb 9, 2010 07:11 PM
jdmdc5integra
11
Jun 17, 2007 04:39 PM
TRR
May 8, 2003 02:32 PM
Integra187
Sep 28, 2001 02:48 PM
