93 gsr turbo hatch idle problems. help!!
Ok, so when I turn my car over sometimes it shuts right back off. I figured that is probably the spark plugs.. Also, when ever I hit boost or go over like 4k Rpm it will sometimes change my idle to 1500 or 2000, and i have to hit boost again to change it back. also, my throttle sticks sometimes.. Anybody have ideas to what it could be? Thanks.
Re: 93 gsr turbo hatch idle problems. help!!
Spray some brake clean in the tb to clean any carbon off the throttle plate
might to adjust the tb plate alittle more. Where the cable attaches to the tb, with the little screw on the bottom
how's the tension of the throttle cable
yea i tried to adjust the screw on the bottom, it doesnt seem to do much.. and the tension on the cable is a little loose.. its a stock tb and at idle it differs. its supposed to be right around 9-1100 but sometimes itll go down to like 600 or all the way to 2000.
yea the boost is fine, staying at 14 and 19 the whole time.. and i just replaced the iac last year.. ill take it off today and check it out and look for leaks on the vaccum lines
It's something to do with your tb maybe you have to adjust the screw that controls how much air goes in at idle (do t kno what it's called) lol
