wrap IC pipe?
Old Jun 8, 2011 | 09:08 AM
sshh's Avatar
Default wrap IC pipe?
i wanted to paint IC pipe to black only for look, then i have been told that wrap it would be good choice also from performance aspect (isolate IC pipe from engine bay heat).
I am not sure ,Is it bad or good?
Thanks
Old Jun 9, 2011 | 09:47 AM
sshh's Avatar
Default Re: wrap IC pipe?
anyone's advice??
Thanks
Old Jun 9, 2011 | 09:56 AM
1FASTHF's Avatar
I have never seen anyone wrap intercooler piping. Hope that helps...
Old Jun 9, 2011 | 10:20 AM
HickamHatch's Avatar
I can only see gains from wrapping if it's close to DP or something else that gets extremely hot
Old Jun 9, 2011 | 11:35 AM
extralargenog's Avatar
NO.
Dont.
Wrap absorbs and holds heat, not reflects it.
Old Jun 11, 2011 | 12:40 AM
turboda4dr's Avatar
^^ i agree with him. alos never seen anybody wrap i/c pipping
Old Jun 11, 2011 | 03:32 PM
turbohatch96y7's Avatar
Ive seen it plenty of times it helps if your intake is next to something hot like a radiator hose
Old Jun 11, 2011 | 07:10 PM
BLU CIVIC's Avatar
Track Advocate
i did some research and was told that you don't wrap b/c you're basically insulating the charge pipes, need to deflect/reflect heat. i went with DEI reflect-a-gold
Old Jun 11, 2011 | 09:56 PM
Better,but it will STILL retain heatsoak.
Old Jun 11, 2011 | 10:27 PM
B and B's Avatar
Loved
Community Favorite
I see turbo diesels wrapped from the oem all the time...foil insulation.
Old Jun 11, 2011 | 11:06 PM
think about it....
Old Jun 12, 2011 | 04:22 AM
DelSolMarine's Avatar
i wonder if there is any iat testing to back up these rational ideas... would the charge piping retain heat soak or not if it is wrapped or coated...
Old Jun 12, 2011 | 04:56 AM
LS AzZkIkr's Avatar
I have talked to the owner of ThermalTech Coatings and he does use a coating that is semi-gloss black and it is designed to help the metal disperse heat better. Check his site out for more info. http://www.thermaltechcoatings.com/ He coated all my hot stuff and I will not do another setup without getting it coated again.
Old Jun 12, 2011 | 09:36 AM
:O)
Yup.
Most OEM chargepipes that are OEM and wrapped with "foil" are steel as well. Aluminum "Foil" over aluminum piping is going to do zero, AND have an adhesive layer between them... One would think that the layer would surely not transfer heat as well as a coating.
A application specific coating has the ability to not only sheild from ambient heat, but to help pull heat out of the piping due to increaced surface area in addition to its properties as well.
1baddturbosi
Apr 21, 2008 03:50 PM
EK FLY
Welding / Fabrication
31
Aug 23, 2005 06:50 PM
civic_driver
Aug 19, 2005 08:09 PM
Boost Addict
Sep 24, 2004 10:12 PM
JSpecwest
Aug 6, 2001 04:18 PM
