A GT35R with a .70 a/r on a basically stock b16.
Old 06-15-2011, 01:00 PM
dE.fUsEd's Avatar
Default A GT35R with a .70 a/r on a basically stock b16.
Motor has only Skunk2 TB and Intake Manifold. Planning on redoing the entire valve train soon and adding cams.
I got a good deal on this kit and was thinking about installing it now for ***** an giggles.
How dumb would it be to put this turbo on now?
Would I have problems making boost? I only want to run 8-10psi.
I have s300 installed already and would be getting it tuned on that.
Thanks for the input..
Old 06-15-2011, 01:07 PM
4cylfiend's Avatar
Default Re: A GT35R with a .70 a/r on a basically stock b16.
A 35r is a pretty good sized turbo and you will have a late "full" spool for street driving. The 35r prob isnt your best choice since you only plan on running 8-10lbs. That would not even be close to its effeciency range. It will still be fun to drive and when you plan on running more boost or installing supporting mods, you wont have to upgrade the turbo.
Old 06-15-2011, 01:21 PM
dE.fUsEd's Avatar
yeah, that's what i was thinking. i know it's not going to be running anywhere near the turbo's range, but I just want something to play around with a bit while I am gathering the rest of the parts.
Old 06-15-2011, 02:07 PM
dE.fUsEd's Avatar
No other input?
Old 06-15-2011, 02:37 PM
rev-speed's Avatar
Originally Posted by dE.fUsEd
No other input?
wtt it for a 30r?
Old 06-15-2011, 02:50 PM
dE.fUsEd's Avatar
Originally Posted by rev-speed
wtt it for a 30r?
lol, no thanks.
Old 06-15-2011, 05:30 PM
turbociv910's Avatar
Fun car. Just put head studs in and make good power.
Old 06-15-2011, 05:34 PM
eg_YANG's Avatar
Just go for it. And when it blows up, u have a excuse
To do it big ballah style
Old 06-15-2011, 08:41 PM
LocoJoe's Avatar
Look at the GT35 compresor map. You wont be even tickling it. That turbo blows after 20 psi. Dont even think of it. Full boost close to 7000 rpms with the .82 hot side on that B16.
GT28 or 30 for you and its fun as hell
Old 06-15-2011, 09:13 PM
racebum's Avatar
lol, no thanks.
while i can't say i blame you for not taking a random trade, that gt30 or one of its variants would fit your engine a lot better
Old 06-16-2011, 10:14 PM
ACTION JACTION's Avatar
What cams are you planning to add? Use a good flowing exhaust manifold and downpipe so you are set when you wanna up the boost
Old 06-17-2011, 09:59 AM
SAMA_BINBOOSTIN's Avatar
im running that turbo on my complete stock b16 at the moment making 320 205trq 10psi only up grade is arp studs car is daily driven everyday and very reliable full boost around 5700 but im revvin it to 8500 and i chose this route because down the road i will be upgrading at the moment i really enjoy it cause its not spinnin tires on the street below 4500rpm heres some pics
http://photobucket.com/boostedhatch
Old 06-21-2011, 05:51 AM
nonpoint986's Avatar
lag lag lag VTEC SPIN SPIN SPIN *shift* lag lag SPIN SPIN *Wheel hop* SPIN SPIN lol
Old 06-21-2011, 10:10 AM
dE.fUsEd's Avatar
Originally Posted by SAMA_BINBOOSTIN
im running that turbo on my complete stock b16 at the moment making 320 205trq 10psi only up grade is arp studs car is daily driven everyday and very reliable spool time are around 5700 but im revvin it to 8500 and i chose this route because down the road i will be upgrading at the moment i really enjoy it cause its not spinnin tires on the street below 4500rpm heres some pics
This is good to hear. This is about where I want to be.
Appreciate the post!
Old 06-21-2011, 09:03 PM
no problemo its not as bad as people make it seem
Old 06-21-2011, 09:08 PM
boostedBLUfg2's Avatar
too big
Old 06-21-2011, 10:07 PM
pcguy760's Avatar
Just listen to people who HAVE used it on the same motor setup as you or similar but as long as they have EXPERIENCE WITH IT. Too much he said she said on here sometimes...
Old 06-22-2011, 07:37 AM
eg:R's Avatar
I drove my buddy with stock b16 with a
35r and it was lagging. Power didn't really kick until after 6k rpm. He was boosting around 18lbs. My 30r felt a whole lot better.
Old 06-22-2011, 07:50 PM
Moderator
TheShodan's Avatar
Even compressor maps don't tell half the story of what needs to be configured when looking at a proper turbo setup. it's about 1/4 of the whole effect. One has to look at the rest of the turbocharger, (turbine wheel, turbine housing, fuel used to reach that pressure ratio), as well as the components surrounding the turbo, such as engine demand flow, VE, and the static compression of the car, so that one can know what boost pressure is needed to make the power desired.
Looking at the compressor map only is like seeing a peep show of a hot girl from a dirty window. Sure you get to see some of the goodies, but you'd rather get rid of the window to get the full clear picture.
Boosted-CRX
10-26-2015 05:12 AM
forryk
12-23-2013 08:47 AM
redline1320
05-11-2011 01:09 PM
type Gendy
11-13-2002 07:06 PM
Quick Reply: A GT35R with a .70 a/r on a basically stock b16.
