Gsr boost?? what # to expect???
I found a 100k original mile gsr B18c1 with original gsr trans integra with boost for sale and was wondering what the expected hp #s could be from the guys turbo setup. The guy says its making around 450 fwhp but i know its probably not true. What do u guys think its making????
Here's the setup on the gsr
Motor (all matching vins on motor and trans)
-GSR B18C1
-full head job valves springs retainers port polished
-ARP head studs
-GSR trans
-450cc
-50 trim with downpipe
-Misimoto intercooler and piping
-jdmsport wastegate
-knockoff HKS bov
-tuned on crome
-Skunk2 manifold
-moroso oil pan
-complete wire tuck
-GSR B18C1
-ARP head studs
-GSR trans
-450cc
-jdmsport wastegate
-knockoff HKS bov
-tuned on crome
-Skunk2 manifold
-moroso oil pan
-complete wire tuck
Also it has 255 pump, skunk 2 manifold as well as throttle body and vtech kicks in at around 4800 If u guys think u need more info let me know so that i can ask the seller
Two things that stand out. First there are no forged internals just head studs so 450 whp would be a little much. Secondly unless you're running 20 psi plus on a 50 trim i dont thing you can make 450 whp . It is probably closer to 300
impossible to say without knowing what that turbo is. is it an authentic garrett 50? a precision 5031e? a 5431e? what is it? to ballpark the good ones will hit 300whp around 10-12psi and you'll want larger injectors. 650s would be a good fit at 300whp.
look in the gsr dyno thread, you'll see a few of these
if it's a china turbo....who knows? impossible to know what it flows
What would u recommend to get to the 400whp safely? injectors? or a bigger turbo and a custom tune? Who would be the best tuner around chicago and milwaukee??
