Adjusting valves on boosted car
Old Jun 22, 2005 | 07:55 AM
jdmb16acivic's Avatar
Default Adjusting valves on boosted car
Should I gap my exhaust valves an extra thousandth or 2 to compensate for the higher egt's or should I just stick with what Honda engineered?
Old Jun 22, 2005 | 10:44 AM
SuperTeg95's Avatar
Default Re: Adjusting valves on boosted car (jdmb16acivic)
I've always stuck with the lowest clearance within spec. Always ran great that way.
Old Jun 22, 2005 | 02:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Adjusting valves on boosted car (SuperTeg95)
the smallest feeler gauge i have is 0.007" i have set every honda b series i have ever worked on at 0.007" i think youll be ok at the stock lash.
Old Jun 22, 2005 | 02:16 PM
Default Re: Adjusting valves on boosted car (boostedcivicsir)
.007" on both in. and ex.?
Does anyone know the stock lash? Is is .008 in. and .010 ex.?
And thanks for the previous replies. I've talked to a few other guys and have been hearing the same thing from everyone, keep it stock.
Old Jun 22, 2005 | 02:19 PM
Mr. Badwrench
should be 0.008 and 0.006
so i spilt the difference and put all at 0.007
Old Jun 22, 2005 | 04:49 PM
y7turbo's Avatar
just use your stock settings.. i tried to go closer and it ran awesome n/a but when i turboed it didnt run right..
factory specs and my **** runs good.
Old Jun 22, 2005 | 05:11 PM
agrn93ls's Avatar
i believe stock setting is .006-.008 intake and .007-.009 exhaust, the .007 for both works. i usually do .007 in and .008 on exh just to be sure not too tight.
Old Jun 22, 2005 | 06:03 PM
Garcia-Racing's Avatar
I do .007 in and .009 ex on honda cams boosted.
Old Jun 22, 2005 | 06:13 PM
platinum00's Avatar
Default Re: (Garcia-Racing)
i have always ran stock settings and been fine.
Old Jun 23, 2005 | 03:39 PM
agrn93ls's Avatar
Default Re: Adjusting valves on boosted car (agrn93ls)
but also dont know what you are aiming for but if it is trying to get that extra little bit of power i wouldnt worry about it on boost like i would motor since the air is being forced in its not that critical. so i wouldnt really go to the minimum on the exhaust or anything.
StratTone
Jul 23, 2018 02:16 PM
hAILO
Jun 23, 2005 06:10 PM
97dc2
Apr 29, 2005 10:28 AM
Dr. Gonzo
Dec 26, 2001 07:10 PM
