Another Vitara compression Q
Old Jun 23, 2005 | 10:01 AM
93turbo16's Avatar
Default Another Vitara compression Q
Did a compression check on my motor. D16Y7 bottom end with a D16Y8 head.. yielded 150 on every cylinder. BUt just thought it might be a tad higher than FJTs readings with just a D16Y7, just wondering if that seems about right. I think it does, just thought I would show what I got. Also This yields compression around 8:5:1?
Old Jun 23, 2005 | 10:34 AM
Darkane's Avatar
Default Re: Another Vitara compression Q (93turbo16)
Did you do the Test at WOT? if not it should change the numbers.
G/L
Old Jun 23, 2005 | 10:54 AM
93turbo16's Avatar
of course! I was just trying to compare to FJT, because I thought with the Y8 head it would be higher. That is all. THe motor has 2000 miles on it.
Old Jun 23, 2005 | 10:58 AM
booscivic's Avatar
as long as the #'s are close you are good~
Old Jun 23, 2005 | 12:30 PM
93turbo16's Avatar
Yea, LoL. the motor is fine. I was just curious about not seeing any difference. It doesn't really matter I guess, it is so small.
Old Jun 23, 2005 | 03:37 PM
fjt's Avatar
fjt
it yielded 150 on my motor when they where just installed..after 7k miles it had gone up to 165PSI per cylinder.
kPRO dz
Sep 6, 2009 07:55 PM
yoffer
Apr 3, 2007 08:34 PM
c1civic
22
Apr 12, 2005 05:52 PM
Malgerus
Jul 23, 2002 08:16 AM
