grinding the block?
Old Jun 25, 2005 | 11:00 AM
VtecAdil's Avatar
Default grinding the block?
what is the best tool to grind down some of the webbing on the block so that my turbo fits. also how much of the webbing can i actually grind before i've gone too far, and also will i be alright if the turbo hits the block a little??
Old Jun 25, 2005 | 05:44 PM
skunkwhat's Avatar
Default Re: grinding the block? (VtecAdil)
grind it with whatever you have, right angle grinder, dremel, ect.
use common sense while gringing on the block.
i wouldn't want my turbo touching my block, but i gues it depends on what your manifold is made out of and the expansion rate of that material.
just my 2 cents
jdong
Aug 4, 2008 08:09 PM
K20 EG
Jun 9, 2003 08:36 AM
