Hondata S200 with out boost option??
Is it possible to run a boosted car with just a S200 with out the boost option?
I have an exellent opportunity to purchase a S200 the guy says he has been running a low boost turbo set up on this @8 psi
that is great because I want to run about the same 10 psi
is this possible let me know
(has any one figured out how to decode the boost option in a hondata unit yet????)
thanx
thanx
Re: (dornon13)
No you can't. When I bought my S200 w/boost, I didn't know that they didn't activate my boost option. Instead, they only gave me the code to unlock the boost option. So as I was trying to drive my car to my tuner, I had to hit boost a little bit getting on the freeway. As soon as my ecu sensed boost, my car shut down.
If you run a S200 without the boost option, as soon as your ecu sees boost, your car will shut down.
you are an ******* anyway for asking how to rip off a legitimate company. i say boost 20psi with the non-boosted unit for you.
may as well ask if anyone has found a way to get around the immobilizer so you can go steal a car.
