Do i need headstuds running 6 lbs on a b18c1 ?
Re: Do i need headstuds running 6 lbs on a b18c1 ? (TheSaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSaint »</TD></TR><TR><TD CLASS="quote">Is it an absolute necesiity to get heastuds at 6 lbs of boost ? I really dont want to take the head apart if I dont have to...............</TD></TR></TABLE>
Is 6 lbs ever enough ? I run 14 daily with stock sleeves, forged internals with headstuds. I dont think you need headstuds, especialy if you are not a boostaholic.
Re: Do i need headstuds running 6 lbs on a b18c1 ? (salt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salt »</TD></TR><TR><TD CLASS="quote">
Is 6 lbs ever enough ? I run 14 daily with stock sleeves, forged internals with headstuds. I dont think you need headstuds, especialy if you are not a boostaholic.</TD></TR></TABLE>
Who isn't one? haha....boost is addicting. First 8psi wasn't good enough, now 15 is no longer enough....I wonder what 25psi has in store for me haha.
Guest
Posts: n/a
Re: Do i need headstuds running 6 lbs on a b18c1 ? (Dunc)
haha well the problem is that I have 200,000 miles on my teggie ! but compression tested at 240 across the board, and I recently put down 163 whp and 124 lbs of torque with just header and exhaust, so I think the motor can take it.......do you guys think that I can get away with 8 , or do you think 6 should be my limit ?
when was your last head gasket change? I'd do it the next time u change your gasket, which could be soon.
