any experienced boost fluctuation with a MBC.....my boost drops a couple psi @ WOT
hey guys, i have a greddy TVVC MBC, and have had it for a coupl eyears, and have never had a problem with it at all.
but i recently got a new turbo and hooked it all back the way i had it, but when i make a pull in 2nd gear it goes to 18psi(where i want it) and then when i hit 3rd it DROPS to like 14-15, and fluctuates a bit then goes back to 18psi???
anyone ever experience this??
kinda like the opposite of boost creep i guess!
Re: any experienced boost fluctuation with a MBC.....my boost drops a couple psi @ WOT (mrbsponge)
Run a restrictor before the MBC (.035" usually works well) and your problems should decrease. This is a pretty common prob with grainger valve setups, takes a bit of tweaking to get em right sometimes. Just be sure to dial the boost way down before you start to dial it back in after you put the restrictor in.
