fuel pressure with JRSC
Old Jun 25, 2005 | 06:55 PM
hondaeg8's Avatar
Default fuel pressure with JRSC
where should my fuel pressure be at idle with a jrsc @ 6psi?
i also have head work done, i was thinking 50 psi at idle
i have a walbro 255lph fuel pump also
Old Jun 25, 2005 | 09:07 PM
EnzoSpeed's Avatar
Default Re: fuel pressure with JRSC (hondaeg8)
Stock. You won't need large enough injectors for 6psi to warrant raising your fuel pressure.
Old Jun 26, 2005 | 12:22 AM
hondaeg8's Avatar
Default Re: fuel pressure with JRSC (EnzoSpeed)
at stock psi fuel pressure, my electrodes on the plugs were pretty white.
i did about 3 pulls and then checked the plugs.
Old Jun 26, 2005 | 12:57 AM
EnzoSpeed's Avatar
If you are running lean, fooling with your fuel pressure isn't going to solve your problem. You need to adjust your injector duty cycle. Oh wait, you aren't using an FMU are you...
Old Jun 26, 2005 | 11:24 AM
hondaeg8's Avatar
for right now.. yeah.. fmu with stock injectors. i have some 310cc injectors, but not using them.
i just put the kit on , so i used everything it came with ecept the injectors.
Old Jul 7, 2005 | 11:01 PM
hondaeg8's Avatar
so for stock injectors, the stock fuel pressure should be kept, correct?
so it would be ~42psi at idle with hose on .
the.hamburglar
Mar 27, 2015 07:58 AM
Kr4nG
Sep 28, 2009 02:31 AM
aalb1
Nov 2, 2005 10:47 AM
hondaeg8
Oct 1, 2005 01:14 PM
Leo95SE
Jun 24, 2002 01:03 PM
