remove the pcv valve?
Old Jun 22, 2005 | 06:03 PM
LSTEG96's Avatar
Default remove the pcv valve?
anyone do this? what are advantages and disadvantages?
Old Jun 22, 2005 | 06:29 PM
s2kdre's Avatar
Default Re: remove the pcv valve? (LSTEG96)
yea you wont get oily resedue in your intake manifold without one.
Old Jun 22, 2005 | 08:37 PM
RMS's Avatar
RMS
you also don't evacuate the gas fumes from the crankcase that get there with blowby (present even on new engines in excellent condition). those fumes condense in the oil, break it down, and lead to premature cylinder wall and bearing wear in short order (not to mention camshaft wear, oil pump wear, etc.). we've seen several crvtecs with rod bearing failure related directly to this issue in conjuction with generic "ebay" chips or larger injectors.
but your worn out engine will have a very clean intake manifold
Old Jun 22, 2005 | 10:13 PM
SOHCmaster's Avatar
I run a breather off the valve cover still, but when I dumped the pvc to ground my car would puff white smoke at idle out the exhaust so I put pvc back on and no more white smoke.
Old Jun 22, 2005 | 10:58 PM
LSTEG96's Avatar
Default Re: (PK SPEED)
hmmm, ok, well stan is selling that endyn moroso modified breather tank, would that be a good idea then? that kinda sounds like it has clean intake manifold AND u get to keep the motor in one piece.
Old Jun 23, 2005 | 07:43 PM
SOHCmaster's Avatar
Default Re: (LSTEG96)
Yeah I think I was puffin cuz I didnt hook up a vac to exhaust, just dumped it and thats probably why.. Ill do it again after I tap exhaust for vac...
42aRanger
Jul 12, 2013 01:29 AM
dannyly17
Apr 27, 2010 08:47 AM
dpkelly
Aug 15, 2005 08:52 PM
976
Sep 23, 2001 12:33 AM
