car is boostin higher and higher in every gear is this ok???
Old 06-22-2005, 02:37 PM
nyjdmhatch's Avatar
Default car is boostin higher and higher in every gear is this ok???
ok i have a red tial small 5psi spring on my deltagate 38mm and in first gear it reads 5psi than second like 8psi than 3rd 10 than 4th 10 is this normal cause i'm scared i'll blow my motor??? should i order the 3psi spring than bring it up wit a mbc to 4psi?? car is street tuned already?
Old 06-22-2005, 03:07 PM
s2kdre's Avatar
Default Re: car is boostin higher and higher in every gear is this ok??? (nyjdmhatch)
no not normal, that wastegate is know to creep like that
Old 06-22-2005, 03:17 PM
Mr. Badwrench
boostedcivicsir's Avatar
where does the waste gate get its boost signal from? if you are pulling it from the manifold it may be causing it. i know everyone flames the delta gate, but for 2 years mine stayed locked at 7 psi never crept, or spiked. make sure you have solid connections, try to catch the boost signal off of the turbo.
but to answer your question, no it isnt normal. and at 10 psi in 4th gear, thats where you will do most of your damage.
Old 06-22-2005, 07:29 PM
nyjdmhatch's Avatar
Default Re: car is boostin higher and higher in every gear is this ok??? (boostedcivicsir)
the vac coming from the turbo the lil port on the side...about if i change the spring to a 3psi will this help? or should i just get another gate ?
Old 06-22-2005, 07:54 PM
Mr. Badwrench
a tial will probably help but i cant see why i didnt have any problems for 2 years but try another gate and see if that helps.
Old 06-22-2005, 07:58 PM
nyjdmhatch's Avatar
i hope so...and it might be something else to i converted from internal to external and welded the external on the manifold my self maybe it might be leaking can this cause boost creep like that??? and my dump tube is open atmosphere?
Old 06-22-2005, 07:59 PM
nyjdmhatch's Avatar
the vac line is on the wastegate but the exhaust for the gate have no dump tube
jdm.fanatic
06-19-2015 06:16 AM
teggy_94LS
01-23-2010 04:51 PM
DelSolMarine
11-16-2008 07:43 PM
the.hamburglar
04-16-2006 01:30 PM
pushinlsteg
11-27-2004 01:28 AM
Quick Reply: car is boostin higher and higher in every gear is this ok???
