boost leak please help!!!!!!
Old Jun 25, 2005 | 10:11 PM
whoneedzvtec's Avatar
Default boost leak please help!!!!!!
i have a 97 integra w/a drag kit. well recently it is leaking boost it will rise to the desired boost level but then @ about 5000 rpm it starts going downmore and more. i have replaced all regular hose clamps with t-bolt clamps and replaced all rubber couplers with silicone couplers and it still does the same thing. i have checked every vacuum line for security and all is good. i have also tightened my bov. is it maybe my turbo going out or maybe even boost controller. thanks all.
Old Jun 25, 2005 | 10:49 PM
lkailburn's Avatar
check boost controller and the wastegate.
Old Jun 25, 2005 | 10:56 PM
Dunc's Avatar
BCICAN
Default Re: boost leak please help!!!!!! (dc2ls-t)
Check the wastegate diaphram. I had the same thing a little while ago...and I had burnt a small hole through it. Worth the 10 minutes to check it out.
0618turbocivic
Jul 16, 2006 03:46 PM
Mag00n
Jun 3, 2004 09:21 PM
r1lorenzini
Feb 19, 2004 11:54 AM
HRC51
Sep 3, 2003 11:16 PM
haq
Aug 6, 2003 11:56 PM
