Those running a Golden Eagle OEM custom head gasket....Help?
I ran a search but couldn't find an answer. I figured most of us FI guys have gone through more than one HG so I thought I would try hear first
I ordered in a Golden Eagle OEM 84mm custom head gasket for my Ls/Vtec turbo setup. I received the HG but the package, which till has the OEM Honda tag on it says P30 as in B16 OEM HG. I was confused thinking I should be getting the custom LS HG, seeing as I have an Ls/Vtec w/ B18A bottom, and B16 head. I checked GE's site and they show the same HG for ALL B series regardless of head/block combo.
Can anyone confirm that I indeed have the right HG? Im thinking that the oil passages won't match up? I also purchased their Ls/Vtec dowel pins.
Please help!
Thx in advance
Modified by GEN2TEG at 10:40 PM 6/24/2005
Please help!
Thx in advance
Re: (GEN2TEG)
From the factory the headgaskets are basically the same. Just the dowel pin holes on the gasket that are drilled out are different between the non-vtec and vtec HG's. What GE does it drill out all four dowel pin wholes so you can run the gasket on either a vtec or non-vtec head.
Re: (TurboLSVtecTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLSVtecTeg »</TD></TR><TR><TD CLASS="quote">From the factory the headgaskets are basically the same. Just the dowel pin holes on the gasket that are drilled out are different between the non-vtec and vtec HG's. What GE does it drill out all four dowel pin wholes so you can run the gasket on either a vtec or non-vtec head.
So they are all the same, except mine would have the extar holes for the dowel pins.
Good to know. Sounds like I have the right HG then.
Thx!
Thx!
