Shimming KAAZ LSD?
Old Jun 24, 2005 | 12:38 PM
importboi22's Avatar
Default Shimming KAAZ LSD?
Trying to finish up my install on a kaaz LSD and i removed both shims, put on both enclosed bearings and set the lsd in the case with no shims on either side..... closed up the case and tq'd it down...... the lsd has a hard time spinning while in there.... and there is no room for a shim! is it supposed to be like this? the bearings are seated all the way down on the LSD and the LSD is sitting flush on both ends of the casing.... anyhelp or input would be apperciated ( SP? )
Old Jun 24, 2005 | 02:58 PM
Default Re: Shimming KAAZ LSD? (importboi22)
bump it up
Old Jun 24, 2005 | 04:06 PM
bump it
Old Jun 25, 2005 | 08:37 AM
toxicshit's Avatar
free bump.
Old Jun 26, 2005 | 08:42 PM
Default Re: (toxicshit)
another bump cuz i havent found out yet!
Old Jun 27, 2005 | 02:13 PM
Default Re: (importboi22)
bumpz0r
Old Jun 28, 2005 | 01:05 AM
another update?
Old Jun 28, 2005 | 09:30 AM
no info
Old Jun 28, 2005 | 10:59 AM
SOHFAST94's Avatar
Simple question:
Why did you take the shims out?
Old Jun 28, 2005 | 08:20 PM
Default Re: (SOHFAST94)
wouldn't fit with them in........ plus thats how you shim a lsd
Old Jun 29, 2005 | 04:06 AM
JAMinCiViC's Avatar
bump cuz i have a kaaz, but not installed by me
Old Jun 29, 2005 | 04:55 AM
SOHFAST94's Avatar
just bouncing around some ideas could it be that the bearings are pressed on too far and the diff is dragging on the case?
Old Jun 29, 2005 | 10:04 PM
nope diff when pressed into either side by itself spins freely
Old Jun 30, 2005 | 12:00 PM
Boofster's Avatar
http://tech.hybridgarage.com/tech/lsd/index.html
bump for interesting question
Old Jun 30, 2005 | 01:15 PM
Default Re: (Boofster)
bump im gonna try some new things today
let you know if it works!
Old Jun 30, 2005 | 08:39 PM
OMG no help?
Old Jul 4, 2005 | 01:58 AM
Old Jul 4, 2005 | 06:01 AM
Aggressive Racing's Avatar
Are you using the tapered bearing or the roller bearing(like in a b16 tranny).
Old Jul 4, 2005 | 02:06 PM
Default Re: Shimming KAAZ LSD? (aggressivemotorsports)
roller bearing which comes in the b16 tranny
Old Jul 4, 2005 | 03:24 PM
Old Jul 4, 2005 | 04:18 PM
nfn15037's Avatar
The B16 ball bearing is NOT the same as a GSR/ITR bearing! If you are using the B16 ones, this is our problem as the spacing is different. Get some GSR/ITR ones and you will be all set.
Old Jul 5, 2005 | 02:14 AM
Default Re: Shimming KAAZ LSD? (nfn15037)
NO WAY?>!?!??!?! =\ oh man thats lame
Old Jul 7, 2005 | 10:55 AM
trying the type R bearings today!
sh!ft
Transmission & Drivetrain
Jul 18, 2014 11:58 AM
please_hop_off
Dec 20, 2009 04:11 AM
HondaPH22
Nov 23, 2006 12:52 AM
hybridhatch18
Nov 25, 2003 06:18 PM
89HF
Mar 3, 2002 10:44 AM
