full-race b18b dyno on low boost
official honda whore
forgot to add it was 100 plus degrees and humidity was unreal
really conservative tune, maybe i can get the ignition and fuel maps and post them up
stock boost 8 lbs
b18b
81.5mm cp's 9:1
eagle rods
crower turbo cams
ported head
crower valvetrain
act xtss clutch
gsr trans
full-race stage 2
t3 60-1 .63 exhaust .70 intake
3" downpipe
3" catco cat
3" thermal catback
turning up the boost when iget some more miles o n the motor, right now theres only 500 miles on it
does this look right?? or should i be making more power?
Modified by coptzer at 5:54 PM 6/26/2005
Re: full-race b18b dyno on low boost (coptzer)
i would think you would of hit a little more power
with my old setup stock ls turbo with drag turbo..i hit 215 at 8psi
You are not going to make "HT numbers" in that weather. Go back to the dyno when you feel you have a good amount of miles on the motor and start tuning for more boost. If you feel you are pushing the limits on pump gas (IAT, knock, etc) dont think twice about using 100 or even 104 octane. Good luck
Re: full-race b18b dyno on low boost (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">You are not going to make "HT numbers" in that weather. Go back to the dyno when you feel you have a good amount of miles on the motor and start tuning for more boost. If you feel you are pushing the limits on pump gas (IAT, knock, etc) dont think twice about using 100 or even 104 octane. Good luck </TD></TR></TABLE>
ya it was soo hot i think i could have cooked myself lunch on my valve cover
im thinking in nice cool weather id be puttin down a good 10whp
plus i only have 500 miles on the motor so it isnt fully broken in yet
when i get around 2000 miles on it im going to throw on my 3bar and going to try n hit mid 300's which i feel should be easy because im not even barely touching the compressors map at 8 lbs
Re: (jdmhonda)
i believe he was using uberdata, h-t member 93turbo16 did the basemap and quick tune to get my car on the road and ready for when i raise the boost up, he is a real kool kid and im looking forward to see what we can hit at around 16-18 lbs of boost
Re: (pumafeet10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumafeet10 »</TD></TR><TR><TD CLASS="quote">did u have the guys from dynamic tuning it on the dyno or were you doing it on your own and where did u have your block built?</TD></TR></TABLE>
The guys from dynamic will never tune with this stuff. The guys at McNew's are good guys, they let me use the dyno whenever I want it. I have a bunch of other graphs that I should get around to posting. The temps in that dyno room are crazy. The kit was a very nice setup and is just awaiting some cam gear tuning and more boost. can't wait to see what happens.
Re: (93turbo16)
im glad you said that about the guys at dynamic i wouldn't trust them with a pinto, who built the block and is there other stuff that u do like fab or things like that?
Re: (pumafeet10)
I don't particularly like how the AF is at 12.0:1 when you tuned in 100 degree weather with high humidity. If you keep this tune over teh winter I would be willing to bet on a cold day your AF's will go well over 12.5:1 and may hit 13:0 or above . Hopefully you have a wideband and can do a street tune laster on. I didn't see what kind of EMS you had, but unless you have Neptune or AEM EMS then your IAT correction will be off. I agree with everyone you could have made more power if it was a nicer day....oh well. GL with that setup
Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">I don't particularly like how the AF is at 12.0:1 when you tuned in 100 degree weather with high humidity. If you keep this tune over teh winter I would be willing to bet on a cold day your AF's will go well over 12.5:1 and may hit 13:0 or above . Hopefully you have a wideband and can do a street tune laster on. I didn't see what kind of EMS you had, but unless you have Neptune or AEM EMS then your IAT correction will be off. I agree with everyone you could have made more power if it was a nicer day....oh well. GL with that setup </TD></TR></TABLE>
It was just to get it on the road. I always add fuel into the whole map after I dyno it. It never leaves the same way it ended.
Re: (pumafeet10)
i put my turbo and everything on myself, built the block myself, basically did everything but tuning, and hopefully soon ill have the stuff to be able to do that, when i get done in school in 9 months i plan on doing this alot more
also a pic of the car for you all
Re: (coptzer)
nice setup. to bad it was so hot. bump that boost, and repost some dyno numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumafeet10 »</TD></TR><TR><TD CLASS="quote">so what are u doing for school are u going somewhere for mechanics stuff, if so where are u going im looking into that myself?</TD></TR></TABLE>
i go to school for a comprehensive automotive degree at stark state college in canton ohio. Best school around for automotive degrees. We have a GM Certified program, Toyota T10 certification program, and a Honda PACT program, along with the general comprehensive program. we have about 20 lifts, and could hold around 54 cars in house. brand new faucility this year, and we have around 100 cars in the fleet, including an RSX, Pilot, AWD v6 acura(CL?), and CRV.
Post up your ignition maps. I believe the lack of power is due to low timing, hot weather, or possibly your camshafts. What are your cams set at right now? Did you degree them when installing them? Chances are you'll pick up a good bit of power by tuning them on the dyno. Do you have any datalogs by any chance you can share? I'd like to see what your IAT's were at.
Your air fuels look fine.... right at 12.0:1 under boost. The last bone stock LS I did was right at 250whp at 8psi on a similar set-up.
Re: full-race b18b dyno on low boost (PrecisionH23a)
Those #'s aren't as bad as they look considering it made amost 190wtq before 5.5k rpm and holds on steady to redline. That's a real fat powerband. I still would say however, that it peaks in tq too early. Even in a stock ls, tq peaks after 6k rpm. If tq peaked later, you would of made well over 250whp. You should look into that.
Re: full-race b18b dyno on low boost (Stewie)
i will ask 93turbo16 to post them up, the cams werent even touched as these were just a cpl baseline pulls to get the cars a/f good enough to drive on while im out breaking in the motor more, i plan on turning up the boost and doing cam gear adjustments and tuning for power when i go back
brian
brian
