Half or Full Size Radiator?!
Old Jun 23, 2005 | 03:43 AM
mrx's Avatar
mrx
Default Half or Full Size Radiator?!
Hallo,
i plan a B16 / SC34 Setup in my 91' CRX. Currently i have a custom made full size radiator but maybe i need another one because its broken and i don't know if it makes sense to fix it.
now the question, who of you run a half and who a full size radiator. with the full size i never had any heat problems but with a half size i'am not sure.
so i wan't to check what other ppl have experienced with half size radiators?
i know that there are a lot of post but i take a short look and didn't found exactly what i want to know...
Thank
Malte.
Old Jun 23, 2005 | 04:33 AM
HXMan's Avatar
Default Re: Half or Full Size Radiator?! (mrx)
I have a half size del sol dual core radiator and dont have any overheating problems.
But if you are doing road racing or high speed runs you may want the full size.
Old Jun 23, 2005 | 05:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Half or Full Size Radiator?! (HXMan)
i have a half fluidyne and it is fine. which is coolbecause i have a ful race sage 3 on the way.
Old Jun 23, 2005 | 08:58 AM
Squirtle's Avatar
I am going full size due to lack of space. Its hard to fit a GT35s under the hood, with your down pipe going down the drivers side.
Old Jun 23, 2005 | 09:50 AM
TheBobFather's Avatar
Default Re: (squirtle)
Do an aftermarket crossmember with a half wide Fluidyne rad. That will free up some room in the front and still keep you cool, not to mention better traction from the new x-member
Old Jun 23, 2005 | 11:41 AM
BlueShadow's Avatar
since you have a CRX your manifold and turbo setup might sit too far forward so a full size rad may not work.Below is a pic of my CRX/B18C with Revhard manifold and Precision T3/T04E. I dont know if flipping the compressor to the passenger side and notching the block would fit, cause I've never seen anyone run that on an EF.
Old Jun 23, 2005 | 08:29 PM
Squirtle's Avatar
At this time I am working with that dilema, I have a GT35s on my B18B block with full race traction bars and my down pipe was fabricated to go down the drivers side so I notched my block to let the S housing sit snug next to the block. A half size would have no room to lean, so went with a full size with about a half inch of clearance.
Old Jun 23, 2005 | 08:33 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Half or Full Size Radiator?! (BlueShadow)
half size is pretty much your only option. if you go with a dual core rad with an aftermarket slim fan, you shouldnt have any overheating problems. while you are at it. pickup a low temp thermostat and fan switch. it helped me alot
Old Jun 30, 2005 | 03:04 PM
88crxhfb16's Avatar
Fluidyne Halfsize.
Old Jun 30, 2005 | 06:44 PM
rmcdaniels's Avatar
I used a dual-core half size. It worked great for street and drag strip use making over 400WHP. It wasn't enough for road course though, I had to get the Fluidyne half size after one day at Roebling Road, temp gauge has never been over halfway since. If you can afford it, get the Fluidyne.
Bsmith1010
27
May 15, 2019 07:23 AM
crxnatic
Jun 22, 2008 01:38 PM
duh naNG
Sep 16, 2007 02:35 AM
yeegsr
15
Nov 27, 2004 08:29 PM
