saturated or unsaturated injectors?
Old Jun 22, 2005 | 06:23 PM
transpar_nt's Avatar
Default saturated or unsaturated injectors?
What determines if you need saturated injectors or not? Is it the engine, the ecu, the obd version? I'm putting an obd0 LS engine into my EG soon and will going boost shortly after that. What sort of injectors would i need? Also, any advice on which ecu to get? I tried searching for a while on the saturated or unsaturated thing, but couldn't seem to find any solid answers.
Old Jun 22, 2005 | 06:27 PM
s2kdre's Avatar
Default Re: saturated or unsaturated injectors? (transpar_nt)
its the injectors that determine, if you get saturated then they just plug in, and peak and hold need a resistor box, anything bigger than 880's are usually all peak and hold,
Old Jun 22, 2005 | 06:29 PM
Default Re: saturated or unsaturated injectors? (jdmhonda)
will i need clips to install the injectors, or will they just pop in? Sorry for all the Q's, but its how a noob like me learns...
Old Jun 22, 2005 | 06:42 PM
Race Egr's Avatar
If you stay obd0 use peak and hold if you are not obd0 get saturated for 550 and under anything bigger use peak and hold with resistor box. You will prolly need injector clips if you are obd0 just ask the company u buy them from.
Old Jun 22, 2005 | 06:46 PM
Default Re: saturated or unsaturated injectors? (NAPIER)
thanks guys!
GT500FTW
Nov 29, 2012 03:10 PM
nolicense526
Jul 31, 2007 06:17 AM
swt_666
May 16, 2007 09:33 PM
dave24
Aug 3, 2006 07:43 PM
eK9aT10pSi
Jul 24, 2005 09:56 PM
