Overheating problem.
Old Jun 25, 2005 | 01:19 PM
B00STED Si's Avatar
Default Overheating problem.
ok well the past two days its been really hot here, like 90's, and whenever the A/C is on at all, the coolant temp raises to about 1/2 way or 3/4 of the way up, usually its 1/4 up on a normal day. so i cant even use my A/C on a hot day anymore without worrying. will an aftermarket radiator like fluidyne, koyo or pwr help this problem??? what can i do to fix this?? thanks.
Old Jun 25, 2005 | 01:42 PM
AspectIndustries's Avatar
Default Re: Overheating problem. (B00STED Si)
Check both fans, to make sure it turns on.
AC condensor fan should always be on, when AC is turn on.
Radiator fan should turn on when it gets hot. usually 2/5 mark.
Listen and feel it, if its pushing strong air.
Or yet, flush radiator fluid? or Refill if needed?
Old Jun 25, 2005 | 01:45 PM
B00STED Si's Avatar
Default Re: Overheating problem. (synik)
the coolant was flushed 8k miles ago when we did the motor build. thank you tho, i will check everything in about 2 hrs or so when the car is totally cooled down.
Old Jun 26, 2005 | 09:14 AM
B00STED Si's Avatar
anyone else???
pyrojeff
Oct 21, 2019 09:50 AM
EK9JSPEC
10
Jul 18, 2012 05:01 AM
clutch6racerone
Aug 28, 2011 06:30 PM
krayziehuh
Oct 19, 2003 01:39 PM
