3 bar map sensor
No. You must remove and block the original map location so that it sees no air, and rewire the 3 bar map sensor to its matching "pigtail" to work. Be warned!! Your engine managment must be able to recognize the the voltage signal from the 3 bar map sensor. it is not something you can just change using your stock ECU w/ no adjustment, or even a "chip".
http://www.lightningmotorsports.com/sveharness.htm
at the bottom. $62 w/ connector. and they are a H-T sponsor.
