How much can i boost?
Old Jun 22, 2005 | 10:24 PM
civiwhip's Avatar
Default How much can i boost?
i have stock b16 sleeves and 9.0:1 compression pistons.how much can i boost? i also have arp head studs and main studs and rod bolts and a cometic head gasket.
Old Jun 22, 2005 | 10:34 PM
eRACING's Avatar
Default Re: How much can i boost? (civiwhip)
I wouldn't go more than 10-12 psi on pump gas to be on the safe side... TUNED
Old Jun 22, 2005 | 11:05 PM
s2kdre's Avatar
Default Re: How much can i boost? (erics99si)
if you have a blockguard you can go up to 20psi all day long
Old Jun 22, 2005 | 11:06 PM
s2kdre's Avatar
Default Re: How much can i boost? (jdmhonda)
lol, stock motors hold more than 12psi safely
Old Jun 22, 2005 | 11:36 PM
lkshs123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">lol, stock motors hold more than 12psi safely</TD></TR></TABLE>
This guy probably does not want to have it tuned well enough to where 12psi will be safe for very long.
Old Jun 23, 2005 | 05:55 AM
B16Civic93's Avatar
Default Re: How much can i boost? (lkshs123)
if you have forged rods, and depending on the turbo you are running. i would say 17-18psi safely. just as long as you get a good tune
Old Jun 23, 2005 | 06:45 AM
Rory Breaker's Avatar
You need to provide your complete setup to get a real ballpark answer.
adseguy's Avatar
Default Re: How much can i boost? (B16Civic93)
WTF guys, seriously. Stop shouting out PSI numbers. Mother of God. I've seen like 10 posts like this in just the past week and I had to correct eveyone everytime. Tell him about the horsepower, tune, and the way he drives it. You guys should know better then to give a number that in the sceme of things means nothing.
Heres a good one that got in a heated discussion https://honda-tech.com/zerothread?id=1277367 , but turned out to good info about stock motors. Since you are sleeves and have pistons and rods. I'd say your restriction won't be power, but instead the turbo efficiency, IC efficiency, injector size, etc...etc. GL with making good power and talk to your tuner, he'll no what the major restriction is.
edit: reading ownz me. I noticed it's stock sleeves, upgraded rod bolts, and forged pistons. With that in mind, I'd say 350-400. This is just a ballpark and you can go higher or lower, but don't overrev though, The rods are still weak.
Modified by adseguy at 11:28 AM 6/23/2005
Old Jun 23, 2005 | 12:25 PM
eRACING's Avatar
Default Re: How much can i boost? (adseguy)
bottom line... 300whp seems to be about the max you'll want to produce reliably on a stock internal b16/b18. Keep it under 300whp and you'll be fine.
924doorEG
Mar 9, 2008 11:01 PM
JDM97EK
Dec 18, 2006 02:31 PM
thugciti01
Nov 2, 2005 01:07 PM
hovic
Aug 28, 2005 05:29 PM
ModlesSI
Feb 2, 2004 02:58 AM
