tuneing
Old Jun 23, 2005 | 12:44 AM
I got a honda's Avatar
Default tuneing
if i had a car that was tuned for 30psi and i had a electronic boost controller and lowered to say 15psi will it effect anything if it was TUNED for 30psi?...or how does that work? will it run the same at 15psi even though it was tuned for 30?? thanx jus wondering
Old Jun 23, 2005 | 12:57 AM
flip1199's Avatar
Default Re: tuneing (iluvboost)
yes it should be tuned for everything under 30. What was it tuned with? did u just jump on the dyno and say let's start at 30lbs?
Old Jun 23, 2005 | 08:49 AM
Dunc's Avatar
BCICAN
Default Re: tuneing (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">yes it should be tuned for everything under 30. What was it tuned with? did u just jump on the dyno and say let's start at 30lbs? </TD></TR></TABLE>
^^^Agreed 100% If it has a "good" tune, then it it tuned for very amount of boost and every amount of load under WOT @ 30psi. Therefore, if you have a good tune, then lowering it to 15psi will not change anything at all except your whp level.
Old Jun 25, 2005 | 01:14 PM
Default Re: tuneing (Dunc)
sweet thanx i was just wondering
Easyslider01
Sep 30, 2006 09:45 AM
b16 matt
Sep 15, 2006 12:18 PM
project civic
Apr 26, 2005 07:49 AM
Del$olB16A3
Mar 26, 2005 08:44 PM
CivicEJ1
Jan 2, 2005 12:33 PM
