APEX AVCR boost controller help
Old Jun 23, 2005 | 11:35 AM
integraboosted's Avatar
Default APEX AVCR boost controller help
I have an apex avcr on my boosted integra with a tial 35mm wastegate when the avcr is set to off setting which is 4lbs on the wastegate the car runs fine when i turn it to setting A which is 10lbs of boost the car starts to sputters on 5000rpm to redline and the connection of the avcr is the COM connection which is the top of the wastegate and the connection NC is connected to the bottom of the wastegate
is there any other connection or settings that u guys know on a turbo honda setup with this boost controller thanks.
Old Jun 23, 2005 | 11:52 AM
beepy's Avatar
Default Re: APEX AVCR boost controller help (integraboosted)
The boost controller does a very simple thing: It increases boost when you ask it to. It has no control over any other part of your engine, and thus the only possible problem is that your engine isn't tuned right for 10 PSI.
Old Jun 23, 2005 | 11:59 AM
dustin's Avatar
You also have the boost controller hooked up wrong.
It should be like this:
you want it like this:
1) boost source->side port on wastegate
2) boost source->NC
3) COM->top port on wastegate
hold your breath
Mar 6, 2007 07:47 PM
GDM Z28
Nov 30, 2003 06:13 AM
teamrocket si
Feb 10, 2002 02:27 PM
